Multi-Camera to Disc at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old February 11th, 2005, 09:52 PM   #1
For my corporate filiming, I would like to be able to take 2 different cameras direct to disc. I use Vegas 5. Has anyone seen a setup that allows 2 different streams to come in to a firewire card and capture to 2 seperate files? Is this possible or would I need 2 different computers each capturing the footage?
Thanks.
Brian Burns is offline   Reply With Quote
Old February 14th, 2005, 04:57 AM   #2
RED Code Chef
To the best of my knowledge this is not currently possible. I read
somewhere that the system gets confused. I've seen it done with
USB webcams though....
Rob Lohman, visuar@iname.com
Old February 14th, 2005, 01:00 PM   #3
You could use multiple cameras with a mixer using S-Video and send the output by way of S-video to the "PYRO A/V Link with Premiere Elements (API-555)".
You would still be recording one camera at a time but have a way to switch from one camera to another.
The link is: http://www.adstech.com/products/API-555/intro/api555_intro.asp?pid=API-555
Using DV Rack, one could compare cameras and make sure they are all setup properly. I think one can use more than one fire wire port and switch between the two with DV Rack and also compare cameras to check for proper setup but not record both at the same time.
As for capturing two or more cameras at the same time on one computer, I doubt that.
Danny Fye
www.dannyfye.com
Danny Fye is offline   Reply With Quote
Old February 15th, 2005, 07:58 PM   #4
Serious Magic
Right now, you can only record a single DV Stream at a time using DV Rack. If you have multiple FireWire feeds from cameras, there is a Menu setting in DV Rack to choose which camera is currently active. This isn't a "clean" switch, meaning that you cannot be recording when changing sources, and there will be a 1-2 second delay while the feed switches over. However, it's useful if you want to compare cameras. Record a bit from Cam 1, switch over to cam 2, use the split screen function with the recorded Cam1 clip and the live feed from Cam 2, etc.
To get ISO feeds from each camera right now, you'd need laptops for each camera, and a copy of DV Rack running on each laptop.
Karl Soule'
Product Marketing Manager, Serious Magic Professional Products Group.
ksoule@seriousmagic.com
Karl Soule is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
