Enosoft DV Processor at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
Old February 2nd, 2007, 09:36 PM   #1
For Windows XP and Vista users, we will be formally releasing the Enosoft DV Processor in March.
The key features include:
Direct-to-disk recording * Live DV-to-DV processing * Synchronized multicam recording * Real-time video proc amp * Real-time audio proc amp * Real-time logo insertion * Real-time aspect ratio conversion * Vectorscopes (video and audio) * Waveform monitor * Live audio and video monitoring * Text overlay/timecode burn * Subcode data editing * Transfer to and from tape * Scene detection * Simple, familiar Windows interface
The introductory price will be $129.
You can download the final beta version now from http://www.enosoft.net .
If you provide your contact details and specify that you heard about it on DVInfo, you will qualify for an additional discount during the introductory period.
John Miller is offline   Reply With Quote
Old February 3rd, 2007, 03:50 PM   #2
John,
Is there any chance of you producing a HDV version in the near future?
Graeme
Graeme Fullick is offline   Reply With Quote
Old February 3rd, 2007, 03:57 PM   #3
Originally Posted by Graeme Fullick
John,
HDV is a much more complex beast! The interframe compression makes real-time color correction etc a lot more challenging.
The first step to adding HDV support to the software would likely be to permit capturing, previewing and the other features that don't require dealing with the interframe compression.
However, as it stands, the software can be use in an HDV environment for monitoring purposes - i.e., monitoring a downscaled SD DV output while recording to HDV on tape.
Old February 24th, 2007, 01:19 PM   #4
THE ENOSOFT DV PROCESSOR HAS BEEN OFFICIALLY RELEASED!!!
You can download it from http://www.enosoft.net
FREE FOR PERSONAL USE
The downloadable version is a personal-use only (non-commercial) version. It has no time limit restrictions.
WHAT ABOUT COMMERCIAL USE?
For commercial use, you can use the downloadable version for 30 days for evaluation purposes. To use the software for commercial purposes, you need to purchase the fully-licensed version. A license is required for every computer on which the software is installed. The commercial version is a separate download, available only from our on-line store.
Until the end of March 2007, you can buy the fully-licensed version for a low, introductory price:
1 - 3 Licenses $129.00 USD (a saving of $50.00 USD)
4 - 9 Licenses $119.00 USD
10 - 19 Licenses $109.00 USD
20+ Licenses $99.00 USD
ARE THERE ANY DIFFERENCES?
Yes. The non-commercial version uses a single threaded decoder/encoder. The commercial version uses a multiple threaded decoder/encoder. On single CPU systems, this makes no difference. On multiple CPU systems (including dual core), the commercial version takes advantage of the multiple processors.
Also, in certain operating modes, the non-commercial version occasionally adds a “spoiler” frame to the processed video. Specifically, this is when the non-commercial version is used in the Device-To-Device mode or AVI-To-Device mode, and the software is modifying the DV stream in someway.
Users of the fully-licensed version get access to private areas on the Enosoft Users Group and main web site. We intend to add new features to the software. Some of these will only be available in the fully-licensed version.
WHAT OPERATING SYSTEMS ARE SUPPORTED?
The Enosoft DV Processor has been tested successfully on the following operating systems:
Microsoft Windows XP Pro SP2
Microsoft Windows XP Pro x64
Microsoft Windows Vista Ultimate (32-bit and 64-bit*)
At this time, Enosoft strongly recommends either Microsoft Windows XP Pro SP2 or XP Pro x64. Other versions of XP and Vista have not been tested but are expected to support the software.
*To make sure all the features of the software work on the 64-bit version of Microsoft Vista, you should install the software from an elevated command prompt.
You must also have a 32-bit or 64-bit CPU that supports SSE2 instructions. The software will not install on a system without SSE2 instructions or on a version of Windows prior to XP.
Don't forget - there's an additional 10% off the introductory price for DV Info members.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > External Recording Various Topics
