Grain animation ?
Hi,
I'm new to the film look, but I can't help noticing the grain animation on the big screen. Do you feel that this soft edge animation is part of the pleasant look of film ? Some packages offer such grain animation, but it really doesn't look quite right. Have any of you tried these techniques? Is it a resolution issue in that the grains are just too big on DV resolution ? I'm also wondering if the grain animation simulations aren't particularly good because they have been constrained to finish the job in a particular time. In audio effects, many non-linear operations are calculated on over-sampled data, thus reducing aliasing artifacts. I am guessing this is a good explanation for why film still has that soft edge look even *after* going back to video. |
Thanks for the link. It looks Grain Surgery offers much control over the grain animation. I'll download the demo and check it out.
Good antialiasing on grain animation for video-rate image processing is still probably too CPU-expensive for today's computers. From rough calculations, it seems like the stuff would run at roughly 1/10 frame/second on today's fastest PC. Video-rate digital signal processing used to be impossible. Almost there ... |
I've had success with discreet's grain matching tools (combustion, inferno).
A tip I remember from the Meyers AE book--
One of the reasons software noise/grain filters look so muddled or different on NTSC/PAL is due to the pre-existing low resolution the material is sourced at. They suggest uprezzing your footage (doubling or tripling the resolution, depending on what you like) and then applying the noise/grain to that, then shrink it back down to DV output resolution and it should look a bit more natural on playback. When shrinking it down, the larger grain should appear a bit finer (is the logic I think). I hope this helps. |
