Film vs. Digital archiving
Starting a new thread here to isolate this topic...
That's fine in theory, but it's not so simple in reality.
Most film archives are not well-funded or staffed or maintained, and film, IF stored properly, has the advantage of being easily "machine readable" even if rediscovered in a vault 50 years later, and able to be copied to the digital formats of that generation. Digital archiving, in order to work, requires somewhat regularly cloning or copying data onto new data storage formats, lest you find yourself holding a deteriorated D1 videotape in 2050 and wondering where you will find a D1 tape machine, assuming even that the oxide is still attached to the tape. And that's not even a tape format that involves the use of a compression algorithm... Digital archiving is a reality, and obviously most movies today even when shot on film end up in some sort of digital file format, so the problems of digital archiving are always being worked out and will be worked out, but clearly the safest thing is to store movies BOTH on film and digitally, hence why most studios make b&w separation masters of their color films, even from digital intermediate files, even for movies shot digitally. I shot one of the first 24P HDCAM features back in 2000, an indie film called "Jackpot", and it was transferred by EFILM to a 35mm intermediate stock for making release prints. I suspect that Sony Pictures Classics, which bought the film, basically stuck the 35mm interneg and the HDCAM masters in some vault, with probably no plans to regularly copy the HDCAM tapes to new data formats as they evolve, so for all I know, someone doing a revival of the movie 50 years from now will probably just restore the 35mm interneg in the vault rather than deal with the obsolete (by then) HDCAM tape format. Modern color negative films can last well-over 100 years with minimal dye fading IF stored properly at the correct temp and humidity. This has been true since the mid 1980's when Kodak and Fuji worked hard to improve dye stability in their neg and print stocks. So there is little reason to drum up fear in people that their films are "deteriorating" from the moment they shot them. My dad recently has been scanning his slides that he took in the 1950's and 1960's and they look great; for all I know, these slides will be more "readable" in the next few decades than the digital stills on his hard drive. The Library of Congress has the original nitrate negative of "The Great Train Robbery" (1906) and they still can strike prints off of it. Long-term digital archiving is still mainly a theory rather than a reality, since basically there aren't 100 year-old digital data files that are still being transferred regularly. Not to suggest that there won't be, just that film has a proven track record and is hardly risky for long-term storage IF handled properly. If it weren't reliable, studios wouldn't be spending millions of dollars storing their movies on YCM's. |
I'd guess that there will be facilities capable of reading an NTFS formatted hard drive several decades from now, as likely so as anyone having a 35mm film projector lying around. Of course you can't hold a hard drive up to a light bulb and view the images stored on it, so film does have an advantage in that regard. :-) |
"Likely" is a slippery term. We KNOW for certain, that we can still project film that is 100 years old... so in that sense, it is certainly more "likely" that we will be able to project it in, say fifty more years.
The speed at which digital media, drives and players is evolving, certainly shortens the 'likely' prospect of being able to play a particular type of hard drive in fifty years. ANy digital archivist will be kept busy 'updating' the storage process. Weird how that works. I can still go by a turntable for my LP records, but have a heck of a time finding EIGHT TRACK tapes... Sony Beta (consumer) decks... rotary dial phones.... gosh, I feel like a dinosaur already. (Side note: n the early days of film, since there was no 'copyright' protection for movies, per se... they simply made paper CONTACT sheets of every piece of the film... and copyrighted those. When many of the old films degraded, it was the paper PRINTS of those films, that were 'rephotographed' into film once again.) |
The advantage of film is that if it is isn't physically destroyed you can shine light through it and capture the images to whatever modern format you want. The advantage of digital is that you can make multiple copies for extra security and (potentially) preserve exact original quality forever, with no worries about dust, scratches, fading, etc. The suggestion to take advantage of both options is the most sensible thing if you really want to be thorough. |
