Puzzled about Frame mode viewing..
Hi!
If I shoot in frame mode on my XL-1 I get 25 entire frames a second. When I watch this footage on a monitor, does the frame get repeated twice? Does it get interlaced again by the TV? To be honest, I like pans better shot on normal 2-field mode than on frame-mode. Looks like PAPAPAPAPAPA in frame mode, if you know what I mean. I believe that in the cinema they also project each frame twice, because the human eye needs about 50 flashes per second to get the impression of continuous movement.... Thanks, Dan. |
If you shoot in frame mode make sure to use a shutter of 1/50th.
This should reduce your stutter. An interlaced or progessive signal are exactly the same from a TV point of view. The only difference is when the image was created (with interlaced one half of the picture is slightly later in time than the other). Your TV will not alter the picture or something. Ofcourse it might look different because the timing of the pictures is different when it is being recorded/captured. |
I don't think in cinema they project each frame twice! :) Is just that it stays longer on the screen... If you cut it down to a very small fraction of time, on the TV screen you have just one pixel at a time, but you have the entire pic on the cinema screen.
The shutter in a film projector has two openings, on opposite sides of the circular plane, effectively projecting the image twice.
The human eye needs 48 interruptions per second to give a satisfactory illusion of continuous movement, hence 24 fps, projected twice. Source: The focal encyclopedia of photography. |
With projection, the picture is not constantly "refreshed" like with a CRT, so the images don't need to be doubled. They are solid and constant. The only thing that would affect the eye's perception of movement is how fast the image changes, i.e. 24fps v. 60fps.
Take a look inside a film projector
Dan's correct, by the way--commercial film projector shutters, like those you'll find in the projectors at your cineplex, complete two cycles for each frame of film, which helps to reduce perceived flicker.
Digital Micromirror Device (DMD) chips as found in DLP projectors cycle in the MHz range! |
