Mounting camera on different heads / QuickRelease plate
I have been using Sony EX1, and EX3 for some time, and are also planning to get a DSLR...
The problem that I have been encountering more and more is mounting the cameras.. I have E-IMAGE tripods and monopods, using small Manfrotto head on slider, and are also mounting the cameras on a crane..The problem is that every head manufacturer has its own plate.. And when I need to move the camera from tripod to crane/slider or vice versa i constantly have to change plates which can be time consuming.. How do you guys manage this? Do you use some kind of quick release plate, the one which base I can mount to a tripod head plate, and then move the camera across different heads... Thank you for help.. |
Re: Mounting camera on different heads / QuickRelease plate
Manfrotto (Bogen) QR577 seems to be the setup of choice. I use it for my monopod and DVMultirig and with a couple of plates all of my cameras can be switched from one to another effortlessly. About $50.00 USD
And for high end option:
Really Right Stuff - Item Listing |
Second the 577. Saved a lot of headache since I have a lot of support gear including a Sachtler tripod which the 577 receiver plate sits atop. That way my cameras all wear the Manfrotto stuff. Easy!
I have a Sachtler fsb4 fluid head tripod, and was surprised to find when I recently purchased a Manfrotto 561bhdv monopod that the Sachtler and Manfrotto quick release rails are compatible with each other. Is that design an industry standard?
The Manfrotto 577 looks quite nice, btw. |
