Mounting Manfrotto 501HDV on tripod
I have been searching for an answer to a problem I have with my video head, the Manfrotto 501HDV - but so far, I have only found posts from people with the opposite problem to mine: a head that won't come off the tripod.
In my case, I cannot get the head screwed sufficiently tightly onto the tripod, so each time I pan counter-clockwise, the head starts to come loose. Maybe the video head will not work correctly with my tripod, which is a Slik Pro 700DX, a heavy, sturdy support - but clearly meant for photography. For the time being, I don't want to spend money on a dedicated video tripod, however. Any advice? Many thanks! Peter |
Re: Mounting Manfrotto 501HDV on tripod
If you look at the underside of the Manfrotto head, you will notice a series of ridges and valleys. On Manfrotto tripods there are 3 grub screws that you need to screw in to lock the head in place.
http://www.digivideo.fi/content/imag...a_ja_pallo.jpg I don't think the Silk tripod has anything like that. If it was me, I'd probably try cutting a piece of gasket material to go between the head and tripod, and once the head was screwed on as tight as possible by hand, give it a couple of firm, but not forceful bumps in a clockwise direction to tighten it. |
Thanks, Michael - the idea about the gasket material is excellent. Never thought about that! Maybe 2 layers of such a material - 1 on the head and 1 on the tripod base?
