August 30th, 2011, 12:13 PM | #76 | |
Re: Tales of wonders and woe - UWOL #21
August 30th, 2011, 12:53 PM | #77 |
Squeezed to wrong with in vimeo pro?
When I play back my video from Vimeo Pro it is squeezed, wrong with for some reason, but not when I play it back from my own vimeo account?
Geir Inge |
August 30th, 2011, 01:26 PM | #78 |
Hmm...a couple other videos seem to be all right, but let me check out the settings again. In the meantime, let's experiment a bit. Go to your video in Vimeo Pro, within the Settings click on video file, use your own player, and put in the link to your file in Vimeo Plus. Hope it works!
Lorinda |
August 30th, 2011, 02:26 PM | #79 | |
It didn't work, so now I will try to delete the file and then upload again, thumbs up :) |
August 30th, 2011, 02:32 PM | #80 |
I can't imagine what the difference would be! In checking the settings on the Pro account I didn't see any way to change it.
If reuploading doesn't work, Geir, try rendering it again using the compression guidelines Mike Sims posted from the Vimeo site: Compression guidelines on Vimeo. The only thing I can see that might cause aspect problems would be the square pixel setting. But why your video looks fine on your Plus player and not Pro is beyond me.
Lorinda |
August 30th, 2011, 02:50 PM | #81 |
With a couple of false starts I managed to upload to the new DVInfo-UWOL Vimeo account. Pretty easy- even for a cranky old curmudgeon like me! Mine seems to play OK, although the HD version stutters a bit on my slow internet machine.
Good-luck everyone! |
August 30th, 2011, 02:54 PM | #82 |
OK, I have uploaded mine. I had to keep it at 720p due to a slow internet connection (it was saved as a MOV file which is not as compressed as MP4). Its a little washed out and a little soft, but it should do the trick. I'm hoping my new Apple set-up that I will be receiving in September will be more conducive to online delivery (I hear FCPX has a Vimeo export 'button' - that should be sweet for this type of work!).
I'll keep the video password locked until the 1st? I noticed a few others were uploading at the same time as me - best of luck to you all!
http://vimeo.com/channels/guerrillafilms |
August 30th, 2011, 03:34 PM | #83 |
Here’s a question for all you experienced hands at Vimeo. Is it possible to choose the Poster Frame or does Vimeo always choose it? I’m not really crazy about the one Vimeo chose. I looked around for a way to do it but couldn’t find it. Perhaps it is called something else? (I just say “Poster Frame” because that’s what Encore calls the frame displayed as a thumbnail in the link to a video.)
August 30th, 2011, 03:41 PM | #84 | |
With Vimeo Pro using the same upload guidelines as the regular service so many people are familiar with, this new setup should dramatically simplify things for everyone; I'm not a UWOL participant, but this development is appreciated nonetheless! I'm constantly awed by the lengths to which Chris goes to accommodate his membership.
As for "washed out", that's typical of Quicktime, which is notorious for--among other things--its mishandling of PC versus TV levels in H.264 (PC and TV levels are 0-255 and 16-235, respectively, though strictly speaking it's only TV luma that goes to 235, TV chroma going instead to 240). The video may well be perfectly fine, and look correct when decoded and displayed by your viewers' systems. |
August 30th, 2011, 03:50 PM | #85 | |
Then I have uploaded my video again, and now it works fine. What I did, was to upload a wmv file, since the mp4 didn't work. Never experienced this before in vimeo, maybe it has to do with the settings and how I render my file from Vegas? OK, after all - it's a challenge, isn't it :) Best of luck everyone. |
August 30th, 2011, 04:01 PM | #86 | |
August 30th, 2011, 04:25 PM | #87 |
Got it! Did it. Thanks Simon!
August 31st, 2011, 04:11 AM | #88 |
Well, i actually managed to scrape something together just in time :-)
August 31st, 2011, 09:54 AM | #89 |
Yay, Rob!
We're down to the final hours. Already looking at some great works ready for rollout tomorrow. Hoping that some of you who have been quiet are just busy putting the finishing touches on your videos!
Lorinda |
August 31st, 2011, 02:13 PM | #90 |
I wonder if I'll finish and woe if I don't. I need to record the voice over this afternoon and fit it to the edit.
