HP DreamColor Inquiries
Ok, the HP Dreamcolor seems like a great monitor. But a few questions about it for you owners/users of this unit:
- What are the options available to feed it the 10bit RGB Progressive signal that is required to take advantage of the monitors full capabilities...via a graphics card? Or are the only options to do this...are via a dedicated card / box from AJA, Blackmagic, MOTU, etc...? - What happens if the monitor does not get this required "10bit RGB Progressive" signal? - Windows and / or Mac platforms; anybody using this monitor with either, both? And how is it working out for you in your workflow? Is one (platform) easier than the other? - How do the images look if you connect a camcorder (via HDMI) or a bluray player or even a gaming system (PS3, XBox)? Does it look substantially better than it would on a (LED LCD or Plasma) HDTV? - Any other monitors out there that you would recommend to compare the DreamColor to? |
I use the Dreamcolor as a production monitor via the HDMI port. I have an HD-SDI-HDMI converter in line when I need to feed that input type.
I've found it to be quite an accurate monitor with tones and colors; it has significantly better blacks than many LCD monitors in that price range. Certainly it is much more accurate than a consumer plasma or LCD. I would love to be able to take advantage of the Dreamcolor engine via the DVI ports, perhaps someone can post experiences and comparisons with these and what would be required to properly convert the signal, drawbacks etc. |
I had researched the DreamColor about 6 months ago and the need for RGB & Progressive in order to use its 'DreamColor Engine' made me not look into it any further. Before I forget, many PCIe cards and external monitoring boxes do only YUV/Progressive or RGB/Psf (progressive over interlaced). For example, all the BlackMagic Decklink cards only output YUV and the Matrox MXO2 outputs PSF rather than true progressive.
The 'DreamColor Engine' enables the 10bit display and all of the color gamut presets (ie Rec 709, sRGB...). To get 10bit from a graphics card, you need a Quadro with DisplayPort or ATI FirePro. However, I am not very familiar with ATI, but I do have a Quadro FX3800. From a graphics card, there are no drivers for 10bit via HDMI and DVI. However, David from Cineform hinted that they are working with nvidia to provide 10bit output of only Cineform video via dual-link DVI. When I asked how that is possible, he responded with "Under NDA". Another reason I didn't like the HP was due to dithering issues. If you are still interested in the HP or just curious, google 'Dreamcolor dithering' and you will find some very detailed reviews. The best alternative in the $2000-2400 range that is very similar in features is the Eizo CG243W. It is a fairly new LCD (Sept 2009), it is true 10bit with 12bit 3D LUT and 16bit internal processing, has several color gamut presets.... This is what I purchased and I love it. Its ability to display blacks is amazing. It does NOT require anything to enable the 10bit display so no worrys there (besides a 10bit source of course). About watching movies, I prefer watching HD movies on my Eizo rather than my $2000 46" Samsung due to better blacks and lack of the crazy contrast which HDTV's suffer from. |
Maybe someone who has definite knowledge of this can chime in? |
I'm using it camera-direct in the field, not from a graphics card, so it's more about the INPUTS on the Dreamcolor. Actually since posting I've been reading up on it and it appears that I may want to stick with the HDMI input, but I need an external processor like the AJA ones to convert the signal so that it suits the HP monitor. Interesting.
While we are on the subject of adapters and such, I shold mention that the Black Magic HDLink might be what you are looking for, Charles. It comes with either a DL DVI or a DP and is under $500 and will give you 10bit (I think, but you should double check).
At the moment, neither ATI nor Nvidia enable 10bit output via DVI and HDMI. AFAIK, ATI is the only one who enables 10bit via DP on their consumer class cards. I read about a pro photog who uses an ATI 4870, Eizo CG243W and Mac Pro and he said that the ATI outputs 10bit via DP. However, if you are an Adobe or Avid NLE user, you must stick with Nvidia and select one of their Quadro cards with DP, which range from $150 to $5000. |
YES, the software must output 10 bit as well. (caps are for emphasis, not yelling :)
Here is a list of software that I am 100% positive which outputs 10 bit: After Effects & Photoshop. I would guess that FCP, Color & Avid MC can output 10bit BUT they must be 10 bit presets/sequences. I am trying to see if Premiere Pro CS5 can output 10 bit. There is various 10bit output support from Cineform; so, if you use it, then ask in Cineform's forum. Are you PC or Mac? I ask because the only Mac version of nvidia Quadro cards is the FX4800, and for some reason, nvidia changed the outputs on the Mac version. The PC version has 2 DisplayPorts and 1 DL-DVI along with an adapter for DP to DVI. And the Mac version ONLY has 2 DL-DVI. What NLE do you use? |
Andrew, if you are set on getting 10 bit via a graphics card, I bet that the FX 4800 w/ DPs works on a Mac for two reasons: 1) on nvidia's Driver Download section, they don't differentiate between 'Mac' and Windows versions - you just select the OS; 2) another member here, Tim Kolb, uses the Mac version in his PC so there is no hardware difference aside from the outputs.
1) Are you planning on using the Mac or Windows CS5? 2) And have you determined whether Premiere Pro can actually display 10 bit? 3) What software do you want to display 10 bit? 4) Are you editing real 10 bit video and not 8 bit converted to 10 bit and what codec/format? |
Once again, just like the model selection in the Quadro cards is restricted on the Apple side...so then go-eth the connections... To review, 4800 for Mac...works on Windows...4800 for Windows...no dice on Apple. |
[quote=Steve Kalle;1549175]Andrew, if you are set on getting 10 bit via a graphics card, I bet that the FX 4800 w/ DPs works on a Mac for two reasons: 1) on nvidia's Driver Download section, they don't differentiate between 'Mac' and Windows versions - you just select the OS; 2) another member here, Tim Kolb, uses the Mac version in his PC so there is no hardware difference aside from the outputs.
** Another inquiry here; what about BluRay discs.....when played back via a computer Bluray player or even a set top player, does it output a 10bit signal? |
Tim,
HAHAHAHA. (emphasis, not yelling :p If anyone here knows whether PPro outputs 10 bit, it should be you Tim. So, what say you? Andrew, I saw your new thread about using both a GTX 285 and ATI 4870 in a Mac Pro. Can you explain how you want to use them because I don't know for certain whether they can coexist with CUDA still working (which is needed for CS5's hardware acceleration). |
Here is another option: Matrox MXO2 w/ Max or MXO2 Mini w/ Max. Both provide hardware acceleration in CS5 and the Mini has 10 bit HDMI output. The downside is that it doesn't act like a computer monitor. It only works with FCP, PPro, PS, AE and a few other programs. If you need to match the monitor to your printer for Photoshop, then you still need a 10 bit video card and LCD.
- Use the ATI w/the DP port to run the DreamColor monitor - Use the GTX285 to take advantage of the MPE in CS5 PPro But...I don't know it that will work as I'm thinking I'll have to connect a second monitor to the GTX285 in order to use the MPE?! Don't know exactly how this configuration would work .... if at all. But I don't know for sure if the DP on the ATI card is outputting a 10bit signal. Which leads me to another thought....what about the DP on the latest MBP's with the nVidia 330m cards?! nVidia sent me back an email stating that none of their G-Force series cards are 10bit enabled. Which leads me to question, why do they even have HDMI's on those cards then?! I'm still awaiting a reply from them on this. |
