Why Aja/Blackmagic or Matrox?
This, hopefully, is a simple question.
I'm not capturing footage on my system but merely using it for compositing/vfx work. I need to work on compositing real time full HD/2K files. Do I need an Aja/Blackmagic/Matrox, etc to connect to my monitors or will the nVidia Quadro FX be enough? I can calibrate my monitors with an external device (I'll probably get an Eizo or eCinema combo and an HP as third monitor). Simply put, if I'm not capturing any data, why would I need any of these cards? I just can't figure out whether I should invest in them. Any help will be appreciated. Thanks. |
Might assist people to know what software application(s) you are working in. Different programs have different capabilities.
If you want to see your work on a video monitor in the correct color space, then you'll need a capture card to output to the monitor.
The AJA Kona 3 gives you the best options for working with 2k on a 1920x1080 SDI monitor. It will allow you to chose between seeing the whole 2k picture or seeing it pixel to pixel with a crop. I think the Matrox MXO 2 might be able to connect you to the HP Dreamcolor so that you can use it's extended color space options. |
Found this from the Luster/HP Z800 Setup guide:
So does that mean I don't need the AJA for monitoring purposes if I have a Quadro FX? |
FWIW, the Matrox products come with colour calibration included. (This includes the 'blue only' mode.)
Andrew |
And even if you do put an SDI daughterboard onto an FX 5800, you're still feeding a linear RGB signal out of it, not a YCbCr signal or a RGB Log signal, like you can with a Kona 3. |
Okay...so the bottom line is that I NEED a card for display, because it's the only way I can see true color if I ever need the log color space. If I'm working in only linear, then I don't need the card, right?
Let me simplify this for you. Someone is paying you to create professional output to be used in a TV show or feature film. They assume that you can create output that will look the same in it's final broadcast or screening as it does in your office when you screen it for them.
That's why you need a capture card & a proper monitoring chain. |
Loud and Clear! Thank you, Arnie...that's all I wanted to know. Now I'll spend time learning how to use it. Thanks again.
My 2 cents:
AE CS5 is capable of applying LUTs and this is the app which you will be finishing on. For Linear work, I can attest to using AE CS5, Quadro FX3800 via DisplayPort to an Eizo CG243W 'hardware' calibrated to Rec 709 and Rec 601 for broadcast output. With this setup, I have not had a single problem with heavy grading and the broadcast playback looking incorrect. I even tried using a BlackMagic Extreme 3D to my Panasonic BT-LH1710W via HD-SDI to see if there was any benefit for 'my' workflow The only drawback with AE is no 10bit output; however, a possible workaround is nesting an AE comp within Premiere Pro CS5, which can display 10bit via Displayport (which is why I have a Quadro and an Eizo). FYI, higher-end LCDs like the Eizo also support 3D LUTs. Just to point out a couple of options for monitoring: Blackmagic has their HDLink with Dual-Link HD-SDI, 2k and DisplayPort output (and 3D LUT). This device connects to a capture card's SDI output such as the Aja Kona 3 and saves you money by not needing to purchase a LCD with SDI input. (I've seen this used with Flame and Smoke systems for client monitoring) The industry standard is the Aja Kona 3 and is supported with Nuke. |
Thanks Steve. I love CS5's linear workflow support. My issue is with Nuke, however -
Since I'm rendering out to DPX log files which will go into DI for grading, I need to approximate a film LUT. However, I've learnt that short of an expensive 2K projector, it is a pointless task to even try for 'perfect' color space. So I'll need to approximate. I have heard good things about the HP dreamcolor monitor and also the cheaper Dell monitors, but they are both LCDs and only approximate the LUT anyway. Here's one issue. The HP must take in an RGB (not YUV) 10-bit signal for its engine to work and emulate film space. After weeks of researching, people have told me that the Aja or BM cards do this, and this is why I need to have them. However - The Nvidia Quadro series does output RGB 10-bit, so I can feed it via Displayport directly into my monitor of choice. But, the Nvidia also sells an SDI card to connect with its Quadro series for 2k Playback - makes one wonder...if the Quadro by itself can deliver 2K resolution for games, why do we need the SDI just for 'footage'? For Nuke, the GPU isn't that important. So where's the catch in - Buying a GTX 470/480 Connecting a YUV signal to a cheap ($1000) dell 27" ultrasharp monitor Calibrating it with a spyder along with support from the DI lab/facility so my monitors approximate their displays just enough so there are no great surprises when they receive the file. Why spend on expensive montiors and I/O cards? Sorry about the long post, but it's been one hell of a week reading through the mucky world of working in linear color space. I'm beginning to feel I must elect Stu for president! |
The problem with using consumer LCDs such as any Dell is that they cannot be calibrated beyond gamma and white point using something like a Spyder or EyeOne(i1). Whereas an Eizo CG243W can be 'hardware' calibrated to any color space in addition to using 3D LUTs.
And...there is a significant difference between a calibrated Dell Ultrasharp and an Eizo CG243W as I have both next to one another. Furthermore, I see no reason to choose the HP over the Eizo as the Eizo can do everything and then some but NOT have the requirements of the HP for video signal. Plus, the Eizo can use a $100 i1 calibrator versus the HP's $350 (in US). It appears as though you don't need a capture card unless you must have client monitoring. Because someone else will be finishing/grading on another system, a Quadro FX via Displayport to an Eizo will work great for your setup. |
Thanks Steve. Appreciate it!
My first preference is the Eizo. Getting it in India is the issue. |
