Monitor for XL1s
I'm looking for a montor to attach to an XL1s but there seems to be too much choice.
Budget. 300GBP (approx 600 USD) Any recommendations? Thanks in advance Dave |
The nebtek is fine, although I found the resolution is a touch low for accurate focusing (it only being 234 pixels, the 7" supports 480 pixels). Good for general monitoring and has a built in speaker which is useful for playback. This is the 7" lcd http://www.icpdas.com/oldweb/products/mmi/ga-700yy.htm I had the touch screen version, from which I removed the touch screen section, whichs makes the monitor sharper. I bought it from here http://www.cartft.com/catalog/gl/17 for about 330 euros... Regards Matt |
Thanks Matt
I'm checking these out now, and I'll let you know how I get on. Many thanks Dave |
Here is my solution, it only costs a little over $350 bucks. A color monitor with the added advantage of a tape backup:
1. Sony DCR-HC26 MiniDV Camera 2. Threaded Hot Shoe adaptor (B&H carries these) 3. Short Firewire cable Then all you have to do is: 1. Mount the DCR-HC26 to the XL1-s 2. Set DV Control on XL1-s ON 3. Connect firewire to both cameras (IMPORTANT NOTE: Make sure that both cameras are OFF before making this connection or you may cause a short) 4. Turn DCR-HC26 ON 5. Turn XL1-s ON 6. Shoot You can use any MiniDV handicam, but I like the DCR-HC26 because it's small and syncs with the XL1-s. The advantages of this method: 1. Cheap 2. You can create a backup tape to use for playback and/or to protect against dropouts in the XL1-s 3. Color monitor mounted on top of the XL1-s 4. You have an extra camera with you, in case of emergencies. Not broadcast quality, but useful nonetheless. 5. Firewire carries video and audio to the DCR-HC26, so you do not need to connect additional audio cables. There you go. A color monitor with tape backup for less than $400 bucks. It works for me. Have fun... |
One other thing:
The DV control on the XL1-s will start and stop tape on both cameras, so the shooting is normal. I believe the timecode also transfers. That's it... |
That is one stonking good idea Brad
Cheers mate! |
Hi Dave,
Its good to see a fellow norwich man on the forum! Another good place to find a broadcast quality monitor is that well know auction site that we all know about! I have just bought a sony 20 inch monitor from a production studio that went bust, worth £500 only paid £55!!! |
Hi Chris
Nice to make your aquaintence. We call ourselves Gemini Video, based near Fakenham. Be nice to have a chat sometime. Regards, Dave |
