Apple TV for wireless monitoring?
Can I use the new Apple TV to connect to the HD100 component to a HD monitor and watch the live shot?
Great question, Brian. At $299, I hope Apple TV will work like that.
While listening to Steve Jobs, I saw component inputs and 802.11 b/g/n. Maybe there's a way to rig it so that it can broadcast live output (maybe not full rez quality but at least crew members can watch the live shot)? I think this may be what Brian is thinking about.
http://www.apple.com/appletv/connect.html |
I thought of something that might work. I have seen people connect their camera directly to a laptop and get a live signal. There has to be a way to then transmit that to the Apple TV, maybe through a small Computer such as the Mac Mini, and then to a HD monitor. I cannot tell you what a help that would be. Right now I am running long cables from the camera, hindering my mobility, to a HD monitor. I Dont trust the HD100 monitor, or even a 7". I only use 23" for focus and image, especially because I use the Mini35.
Is there a Component to DVI cable available anywhere?
We Europeans can't get out hands on this for a while, so why don't you buy one and do some tests for us?? LOL
Andrew |
1 Attachment(s)
So your goal is to somehow use Wi-Fi to transmit a live feed from the camera to a monitor? Unfortunately, there really is no good way to do this digitally. The major problem with this idea is that there will be latency of probably almost 1 second due to the mpeg2 encoding and firewire transmission, before the data is even transmitted. Keep in mind that the AppleTV as it is sold is only a media player that can interface with iTunes, which uses MP4 and H264, not Mpeg2 TS. Since it has a USB2 port I would assume that a keyboard can be connected and it could be hacked to boot OS X and run other apps. If this is so, let's assume that the AppleTV is essentially a mac mini without an optical drive, and we can use any software we want. So what software could we use to do what you want? Well, the datarate of Firewire is too high to transmit wirelessly, but if you used a Macbook or PC laptop running DVRack or an NLE capture utility plugged into the camera, you could then connect via wi-fi to a mac mini or hacked AppleTV running remote desktop/Timbuktu to watch the screen. Keep in mind that the frame rate would be very low due to the way remote desktop scans the screen and transmits still images as quickly as the bandwidth will allow. The best bet really would be use microwave HD transmission which would be very very expensive, but give you real-time full resolution wireless that would transmit very long distances. http://www.rfcentral.com/products.shtml http://www.bms-inc.com/product_digitalcofdm.htm http://www.nucomm.com/pdf/041_datasheet.pdf http://www.mrcbroadcast.com/products_core/mobile.html Attached is a photo I took at NAB06 of the HD250 and a BMS microwave transmitter. |
From what I can gather the Apple TV box just transfers (or streams on the fly) files over a standard wireless network. I guess theoretically if it can play MPEG2 then it could be playing back the same m2t stream you're saving to a laptop via HDVrack or something... but I doubt it would work very well (if at all). Certainly wouldn't be in sync.
In any case that solution doesn't really require an Apple TV box per se - just two wireless network devices, one that can handle capturing video and one that can handle playing it back (such as two laptops). |
...but I could convert my HD movies to H.264 and stream them to the Apple TV to watch on my HDTV.
Am I correct in thinking this? HD-DVD/Blue Ray DVD players not readily available in the UK and the prices are too high - I have no way of viewing any footage in HD from my HD100. The apple TV might be a way to achive this. Andrew |
Also, I record AUDIO seperate to a laptop, so syncing sound isn't an issue either as I listen to sound seperately. I was under the impression that the Apple TV transfer HD, but I am not that technical with this, so what Do I know. My goal is just to be able to monitor what we shoot BEFORE we shoot it and during the shoot. AND within a reasonable distance. It may be unrealistic or way to costly for me to archeive, but .....when you wish upon a star, your dreams come true... |
