A7S project (Not wedding) - Page 3 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old July 29th, 2014, 04:22 AM   #31
Re: A7S project (Not wedding)
Ceremony/Speeches - Canon 85mm f1.8
Stabiliser Shots - Canon 17-40mm f4 L
Everything Else (Handheld) - Canon 35mm f2 IS
I'm getting a weird lens type flare when there is a bright light just outside of frame. I'll post a sample of that too.
Clive McLaughlin is offline   Reply With Quote
Old July 29th, 2014, 04:43 AM   #32
Is that with all your lenses? lens flare is often linked to the lens only, like I have a 12mm f2.0 from olympus but you also have a 12mm f1.6 from slr magic, the last one is known to flare a lot more then the Olympus, some get that lens just because of that effect but you can decrease the flare by stopping down the iris, that at least works on the slr magic, not sure how that will work out on your Sony.
Old July 29th, 2014, 05:02 AM   #33
Philip Bloom noticed that the sensor has a bit of a purple flare on the left of the image with some lenses. If that's what you are getting take a look at his review on the A7S
He mentions it somewhere in here but the content is a good watch anyway
The evolving review of the Sony A7s now with extreme low light video. | Philip Bloom
Chris
Old July 29th, 2014, 02:01 PM   #34
Here is the lens flare type thing I experience... Any thoughts?
Old July 29th, 2014, 03:50 PM   #35
Pretty sure that's lens related, somehow catching a "bounce" off those lights off to the side... maybe a hood would help?
Old July 29th, 2014, 04:02 PM   #36
I see that philip bloom has reacted on the vimeo video saying it happens with a sony lens he has as well.
Old July 29th, 2014, 10:48 PM   #37
Having run into a few odd lens issues (small bits of dirt, odd flares, the infamous "blue dot"...) here and there, my guess is that those lights somehow were bright enough to bounce off an internal wall off the lens, which then flared onto one of the elements, but that's just a guess based on the very odd flare you're getting (happens AFTER the light is out of the frame!). Thus my suggestion that a hood might be in order to prevent "off angle" light from entering the lens.
I don't think it's likely the camera... that would be a really nasty mount gap! If that's even a suspicion, you can try the hair scrunchy trick to cover the lens/body joint and see what happens.
You should be able to repro this under controlled conditions with a bright light until you get to the bottom of the problem! That's what I've done when dealing with odd flare artifacts...
Old August 1st, 2014, 09:17 AM   #38
Hi Clive, thanks for sharing. I got the A7s too and I'm struggling with S log 2. Did you use colour curves and colour corrector to get the look? I noticed the Saturation needs to be pushed real hard to get there. In low light its really noisy in 32bit but in 8bit it doesn't "look" that noisy in the preview strangely!
Firewerkz Films SGP
Sean Seah is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
