I love church sound guys.
I'm loading footage from the wedding this past Sat. We used 2 cameras, the camera up near the alter had a Sennheiser lav and the balcony camera had my AT shotgun mic. The audio from the AT is beautiful with the exception of the faint sound of music that was bleeding through the sound board into the churches speakers. You couldn't hear during the ceremony but the shotgun picked up. Good thing the lav picked everything up.
I love church sound guys too. I am one. In fact, the only place I really want to tape a wedding anymore is at OUR church where I KNOW I can get good sound.
Most of these guys are volunteers (I'm a church video guy, I work alongside the sound guys). Every church is different, but there's usually one guy with more training/experience than the others. But you have understand their limitations and work within them.
1 Attachment(s)
Like this?
Hope I didn't offend anyone, I was just venting. As someone who has run sound professionally its just a little frustrating.
No offense. And you're correct. There should NOT have been music coming from somewhere else.
As mentioned earlier, most church sound guys are volunteers. Of those, few have any real understanding of the equipment they operate. Nor should they have to be knowledgable. They just want the sound system to work ... and hopefully the person who talked them into the sound system they have really understood the real needs of the church. I have found the opposite is far too common.
However, there are two easy ways to resolve audio feeds from church PA's IF they use a reasonably sophisticated audio mixer and IF you can get permission to make a few minor adjustments. 1st: Connect a camera to the audio mixer's RECORD OUT RCA connections. This is a constant high level feed from the sound board that is not affected by any adjustments made to the board's master control, but any adjustment made to any individual audio channel will be immediately obvious. Set the camera to LINE INPUT or use an interface. 2nd: Use the AUX SENDS to feed your camera. They are the two control knobs directly beneath the tone controls and above the pan control. Most audio mixers have two audio sends (often labeled as AUX 1 & AUX 2) that are not directly related to the main audio outs. Their purpose is to redirect an incoming signal from a microphone or instrument to a more sophisticated audio processor, which is then returned to the mixer and blended with all other channels to get a more precise sound mix. AUX 1 is usually PRE-FADER, meaning the audio signal is identical to the incoming signal but not affected by the fader setting on that specific channel. AUX 2 is usually POST-FADER, meaning it is affected by any individual channel's fader setting, as well as tone control & pan settings. Both AUX 1 & AUX 2 have their own master, independent of anything else going on with the sound board, and do not necessarily have to be returned to the mixer. I suggest connecting to the AUX 1 OUT on the back of the board. It is usually a 1/4" mono connection. You bypass any church sound board settings and any church sound guy's behavior. The down side is that the audio is a mono feed, and you will have to do audio tweaking in post. At least you will have a stable signal to work with. |
Waldemar,
You offer excellent advice. That was definitely an option but since I was set-up in the balcony I didn't want to run any cable up the balcony. I think I am going to invest in a second lav set-up with an instrument style attachment on the transmitter side that I can use strictly for patching into the house mixers. |
I could give you a feed but, in our case, I'd rather just record to CD and hand you the CD afterwards. Earlier this year, I was running sound at a wedding in our church. I'm not sure where they found the videographer but he didn't even have an external mic on anybody in the ceremony. Don't know if he used it but I did give him a CD with EVERYTHING mic'd. |
Providing the videographer with a CD recording of the ceremony is a very generous gesture. |
It's a different concept when the wire plugged into input #14 is actually on slider #1! Totally alien to the analog boards. It's the first electronic board I've used but the more I use it the more I like it. |
