DV Info Net (http://www.dvinfo.net/forum/)
-   Wedding / Event Videography Techniques (http://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   Glidetrack for... (http://www.dvinfo.net/forum/wedding-event-videography-techniques/476899-glidetrack.html)
Ryan ONeil April 15th, 2010 06:48 PM
Glidetrack for...
I'm needing to find a glide track for my hdr-fx1. Is there one out there for that big of a camera?
Philip Howells April 15th, 2010 08:09 PM
Ryan
I own two lengths of glidetrack based on the popular cast track and use them with a Z1 which isn't very much heavier than your fx1. They're well made and look professional but you should be aware that all track bends to a certain degree but that cast lengths like ours bend more than better designed items. The fact is that circular section or box sections bend less than a single cast unit - so little that you could well regard them as unbending for most non-critical applications like video.
I suggest you contact Chris Harding, a member of this forum, by PM.
Chris Harding April 15th, 2010 08:41 PM
Hi Ryan
I made up a DIY glide track with door track aluminium square section around 50" long and this still bends a tiny bit at the end but then again, my all up camera weight is around 8lbs!!!
I have been tinkering with a new idea, spawned by Philip, using round tube which is theoretically the stiffest and using a track with 2 x 3/4" aluminium tube there is no deflection at all. (Philip said his engineer friend told him this is the only way to go) The only "disadvantage" is that the carriage I made is no "captive" but I have had no issues with it. The carriage is basically an aluminium frame with two bits of angle running longitudinally it has 8 x 3/4" bearings mounted so the "wheels" can conform to any mis-alignment in track width too. Runs as smooth as silk and cost me less than $50 in parts!!
If you want more details I will finish it after the weekend as I have a wedding shoot today and tomorrow
Chris
Josh Fung April 15th, 2010 10:54 PM
I'd be interested to see you project Chris. Do keep us informed!! :)
Ryan ONeil April 15th, 2010 11:08 PM
Originally Posted by Chris Harding (Post 1514878)
Hi Ryan
Chris
I'd definitely be interested. Thanks!
Kren Barnes April 15th, 2010 11:45 PM
yeah me too...will you be posting some sort of DIY instructions? cause that is really interesting...
Dror Levi April 16th, 2010 10:53 AM
Hi Ryan,
Hi build one myself that works with my fx1000 and 7d and it works great.
I actually got the wider and stronger track that cost me less then $200.00 to put it all together.
Ryan ONeil April 16th, 2010 12:40 PM
Dror,
Do you have pics? Instructions?
Chris Harding April 16th, 2010 05:43 PM
Hi Guys
Will do after I get rid of my two weekend weddings!! There is an easy way too using DryLin track which is ready-made!! See here
http://www.dvinfo.net/forum/dolly-tr...39-slider.html
Chris
Renton Maclachlan April 16th, 2010 06:37 PM
Drylin track is VERY expensive here in NZ...
1998-2019 The Digital Video Information Network
