waterproof white balance cards ?
Hello,
Has anyone tried the WhiBal black/gray/white cards for color balance ? I'm looking for a waterproof card that can be used in a fish tank in conjunction with a flash. Yes, this is a wedding forum, but most of the good white balance threads can be found in this home. Thank you, |
oh, here's the Whibal site
The PortaBrace card is one solid piece of plastic, but its only 5 bucks, so it may not be a sexy enough solution. If you want to spend more money, get the ExpoDisc and just turn the cam around and WB toward the light rather than the reflected light.
I like the price, but I can't tell how big it is. What are the dimensions of your card ? I searched the Portabrace web site, but there is no mention of their white balance card. I would like a white balance card that is durable and cheap, as my Kodak white cards are soiled too easily.
http://www.bhphotovideo.com/bnh/cont...ughType=search Hmmm. Now that I think about it, I guess I could just take a picture of the light reflected off my Kodak grey card. I just didn't want to mess with taking apart the hood. Thanks, Gints |
I was too lazy to view the links others provided..... But you might try shopping a dive store. They should have good waterproof cards that divers use to write messages on while underwater. Don't know the current cost, but I thought I'd throw this into the suggestion box. Sinceres, Steph |
Gints,
I just pulled mine out to measure it: 6 inches by 9 inches. It has a brass grommet and tough nylon cord. It is also one solid sheet of plastic and not a piece of paper wedged between two sheets of acetate, so water can't leak onto the card while submerged and ruin it. For five bucks I think you can't go wrong. Worst case is, you get a really durable WB card for your kit that didn't meet your needs for this shot. But I thinks its exactly what the doctor ordered. |
Why not just laminate a piece of white card/paper. It will last as long as a purpose made white card, and can be made to fit any size that suits. Cost is pence/cents instead of pounds/dollars and very quick to do...asumi9ng you have a laminator of course.
A piece of white plexi works fine for me. I have one that has slate information on one side and use the other for balancing. 2 for one.
Thanks, Patrick. Your plastic white balance card sounds perfect,
as its size is just about right. The WhiBal sytem looks good, but the cards are very expensive. I'm not even sure how well plastic works with its reflective properties. |
