Rock Concert - Is there a filter to make the footage shakier?
It seems like a funny question, but since I primarily film weddings, my focus is usually on making the camera as steady as possible. I recently filmed a 4 camera rock concert with the intent of using the footage to put together a short "music video" using their CD audio. With most hard rock concerts I've seen live videos for, there are a lot of split-second cuts, and it is mostly shaky or quick movements (purposefully, looks like). I can make the short cuts no problem, but I'm just wondering if there is any filter in Premiere (I'm on a PC) that would do the opposite of stabilization? I wanted it to just sort of move the image around randomly, in no specific pattern.
Re: Rock Concert - Is there a filter to make the footage shakier?
Mercalli on my Edius system can work both ways - stabilise or shake.
Hey Tom - trial this: Digieffects - Plug-ins - After Effects, Final Cut Pro, Premiere Pro and Edius
Thanks to both. Tom, I've got Mercalli v2 but can't figure out how to use it this way (and have tried looking at their website, and looking at the plug-in). Any guidance?
No guidance I'm afraid as I've only ever used it to stabilise. Isn't there a 'preset' to wobble as there is to stabilise?
Just used a trial of the Damage software. Just what I was looking for! I'll probably only use it on the one camera I used a tripod with. But it's perfect. Thank you both again.
Michael, since you are using Premiere I assume you have After Effects as well. If so, there is a plug-in that comes with it called "The Wiggler." To use it simply put a keyframe where you want the motion to start and stop, probably beginning and end in your case. Then tweak the settings to your desire. Hope this helps. Let me know if you need further help as I use it on occasion to add various styles to my work.
GenArts Sapphire - Shake. You can adust every movement x,y,z, amplitude, seed, tilt, etc. All keyframable and can be timed to the music by hand or with trapcode soundkeys.
