Flash memory cards for weddings?
Humbly admitting ignorance, I'm posting these questions here because it relates to wedding work. When considering the new Pannie HVX200, if one records a day long event to flash memory cards, how is the HD content transferred to PC? Is it a direct transfer of a file(s) from camera to computer and how long would the capture process be assuming 4 hours of content? Is capture done via USB or firewire?
Also, if you record in HD and want to downconvert, is that done in the camera real-time during the capture process? Finally, do you believe flash memory is 100% reliable and safe for weddings considering the volume of content you might record and need to capture? Bob |
Well, I think I just answered most of my questions. Seems that the HVX200 would not be an appropriate camera for wedding work. According to a review I just found, the P2 cards cost around $1,400 each (yikes) and hold around 8GB. You also need something called a P2 Store HD for around $1,800 (yikes, again).
But the real killer is that around 15 minutes of shooting fills the 8GB card so you have to transfer the footage to the P2 store HD and then erase content so you can use the card again. Unless someone has better info, this makes flash memory for weddings impractical at least for now. |
The production budgets of weddings do not justify the use of HD at this point. Use the most reliable camera you can afford.
-John |
If you can afford enough P2 Cards to do a wedding you have no reason to be working doing a wedding and you should be sitting with your heels up in the French Alps siping very expensive champagne.
Mike. |
