Another new website
I've been able to avoid the website thing for most of my career to date. Just talking to designers felt like being on the inside of a tennis ball during a match. Made the whole thing very intimidating. I finally got the courage to face the issue and, since I couldn't find a designer who listened, built my own. Used the easiest application I could find.
Please visit: http://www.winklervideography.com and critique. Thank you. |
Wade thanks for taking a look at my site, I already made the changes to the text. good idea. I really enjoyed your site, easy to get around! The immersive real estate video was great. Do you have a specialized camera that can do that, or do you stitch a series of photos together?
Just a suggestion, but down res your graphics on your site. It will load faster. I have DSL and it took a while to load. Secondly, if you are interested in free web searches, I would use plan text since graphics are not searchable.
I like the layout, easy to get around. I use a macromedia product call Fireworks but I would assume photoshop would work as well. I just think Fireworks is easier. If I am not using plain txt and would like a certian font, graphics are the way to go. I usually compress them to a gif at the lowest quality that I find acceptable. Fireworks makes roll overs easy to create as well. Good luck, Jon |
The VR "movie" is stitching images together, but don't expect the simple stitcher features of Photoshop or similar apps to do the job. You need an application that allows precise adjustments. I use VRWORX. The"movie" is a combination of Camera, lens, a special tripod head, and specialized software. If you purchased the best of the best, figure $2000 - $3000 investment. However, just about any digital camera will do the job. Key is having the right tripod head and the right software. Visit the following site for loads of information: http://www.ivrpa.org |
The resolution of the images isn't to high, but they could be significantly more compressed, with very minimal (if any) loss in perceived visual quality. I'd suggest using JPEG. If I recall correctly, PNG isn't supported by some browsers that are still commonly used.
The text fonts I use are supposed to be web standard, and I avoided incorporating text into a graphic to encourage searches. I've noticed a lot of sites have a lot of words and phrases way down at the bottom of their pages. One Denver videographer must have hundreds of these words at the bottom of his site. The text color so closely matches the background it is almost not visible. Is there any real value to this tactic? Or is it just tasteless? Thanks for the hint regarding fireworks. I'll look into it. I'm currently using iWeb, which does some really neat things at the expense of some flexibility. |
Yes, I was referring to the still images. For example, the first image you see on the first (index) page is a 648x402 PNG, with a file size of 360K. I would think that image would look just fine as a JPEG, compressed to a half or a third of that file size.
To get the same text into the page, that you are superimposing over images (as text), you could incorporate the text into the images and use the ALT attribute for the IMG tags instead (and be assured of how the text will display).
I'm pretty old school when it comes to web pages. I always edited html manually with notepad (and it's been a few years since I've done any websites). I never did learn to use any of the automated editors.
I would suggest you add your Waldemar...... tag line to the front or as your "Title" on each html page, also add your keywords and discription meta tags in your source code to increase searchability.
down the road,, Submit your site to Google Maps via the Business area. It will take a few weeks for approval and processing. |
Nice set up and great layout, however there seems to be a problem with your menu at the top. Not sure if it is just my computer, but your "Respected Vendors" did not appear at all until I rolled over it once, but then it stayed, and your "Legal Video" is only there when I roll over, but it is gone when I roll out. (this is all from your Home Page)
Just a note on top of that, I have been sitting here for a couple minutes and it still says there is 1 image downloading. Definitely something to look at... You have a really nice start though! |
