Anyone use Gearshift ?
I just found this
http://www.vasst.com/product.aspx?id...d-aa4954c324a3 it sounds like it would make editing so much easier. How long does it take to convert the clips ? |
It takes the same time Vegas takes to render/transcode. It is Vegas doing the rendering, Gearshift automates the button pushing.
Some formats really need it (AVC HD), and for other formats you don't necessarily need it. If you are on a slower computer then Gearshift will help. |
How does the dv proxies work or is that something you can do yourself too.
The DV proxies are used for quick editing at SD speed. Then when you are ready to render, you press the ShiftGears button and all of your HD media is swapped in for a hi-def render. Push ShiftGears again and the proxies are swapped back in for more hi-speed editing. GearShift has a 15-day fully functional trial so you can try it out on a project and see for yourself. ~jr |
