Audio Crossfade shortcut?
Hello all, is there a keyboard shortcut to doing an audio crossfade between 2 clips? The video crossfade shortcut is "/" but is there a way to automatically have the audio crossfade accordingly or even an equivalent shortcut? Thanks.
The same key will also work for the audio.
Thanks Edward, that worked, but it seems a little clumsy to have to select the audio track or the video track in order to apply the crossfade to an event. Is there a way to tell Vegas to automatically apply the crossfade to both the audio and video with the "/" key press without having to first select the tracks? I'm using a ShuttlePro2 and am programming the keys for efficient work flow in my evaluation of Vegas. Many thanks.
Kevin |
I usually just overlap the clips instead of using the "/" key. That handles both. Of course you could always use a script!
