Do we still need cineform?
I use cineform with Vegas 6.
QUESTION: Are we at the point with Vegas 8.0 that we can edit mpeg2 natively? I do some titles, cross dissolves, keyframe panning, a bit of color correction, and the occassional chroma key. I use the JVC HD100. |
Brian..
Vegas 8b still doesn't succesfully always read my native HD110 files. I always record straight to m2t files on an external capture disk. If I try to open the m2t directly in vegas, I get red frames on the timeline. Fortunately, Cineform's HDLink reads my m2t files OK. The red frames occur when there's a hiccup in the timecode on the file. I've filed a support ticket with SMS over this issue, but, they continue to insist the problem is with the HD110, not Vegas. I would recommend continuing to use CFHD. |
7 improved M2T performance over 6 substantially, 8 took it a little bit further.
8 just ate up a project using 4 live M2T tracks that always had red frame & drop outs in 6. I'm currently using 8 on a doc project with all M2T - it's working fine so far with full frame rates (at Best-Full) and no red frames/drop outs on XP SP2 running on a 3GHz Core2 Duo with 2GB RAM. I don't expect the doc project to be as demanding as the 4-track project. Footage in these projects has originated on Z1, V1 and HD100, captured with Vegas from tape. I tend to adapt my workflow such that efx are not previewed much until final passes, so I'm not bothered much when CC takes me down to 15fps at Best-Full preview. For what it's worth. Your mileage may vary. |
Even though I know Vegas is CPU based, I hadn't thought that horsepower would make a difference in the capability to edit Mpeg2 natively. I would expect a dual core to do it faster of course, but still woulda presumed it'd strictly be a code thing. |
However, M2T is a very highly compressed format with a very large load on the processor to decompress. Remember, this is hi-def in the same bandwidth as standard-def DV - 13GB/hr, 25Mbps. You've got 4.5 times as many pixels in 1080i HDV as in standard def DV with the same datarate. Enter Cineform. Without regard for its other advantages, you've got datarates from abt. 25(medium) to 40(high)GB/hr. That equates to 1/3 to 1/2 the processor load for decompression as native M2T. So, yeah, processor load is a significant issue. (please excuse fuzzy numbers - they're all close) |
I'm editing m2t native on the timeline with a Pentium P4 and I'm pretty happy with it. Of course performance drops quickly when the complexity of the project increases with fx, color correction, etc. Most of the time I try to stick with simple transitions and limited fx.
Seth, can you explain why a camcorder can encode and decode it in real time, but our computers hiccup?
Carl |
Cineform is going to be a real benefit if you want to render the clips a few times like I do, I don't see the degradation in the cineform clips like I do in the m2t clips after being rendered a few times.
I use a mix of Cineform and native hdv on my timeline. I see no real need to rerender raw footage into Cineform, but I never rerender into mpeg2 either except for a final Blu-ray or HD DVD master render. I always use Cineform for prerenders and anything that is rerendered at all.
