Pan/crop and audio
I'm panning/cropping an image and changing its focus at particular points to correspond to the audio track.
Can the audio be played while in the pan/crop window so precise placement of track motion can be made, without having to go out of the p/c window and back to the main view to find the degree of correspondance between track motion and audio? |
F12 will play the timeline whikle the P/C window is open.
Don |
Thanks Don.
That gets the cursor moving down the timeline and playing audio, but it does not get the cursor in the pan/crop window moving so you can see where you are re track motion. How does one get the P/C cursor going with audio? |
Thanks Darrin.
I see now how it works. The P/C window cursor soes not move in time with the timeline cursor but can be sync'd to where the timeline cursor is. That helps. |
No, it is not dynamic in the way you/I want.
Here's what I do. 1] Apply Markers on the Main Timeline. These Markers are at the positions OF the audio changes - beats, keychanges, silence . .whatever . . 2] Get back to Pan/Crop, using the Synced Cursor and MOVE the P/C cusor to Marker 1 - seen on the Timeline. Change the P/C. Move to Marker 2 - make the P/C change . .and so on and so on . . Personally I'd like to have a dynamic option too, PLUS a movement Envelope that would HOLD my tracking as I swung stuff about. We have "Latch" for audio - how about the same for Movement? Grazie |
