Chroma subsampling
I plan to shoot HDV 1280x720 which is 4:2:0. What would it be if I subsampled the footage to 640x360? Can I get 4:4:4? What will it be if I use Vegas to do the subsampling? I plan to do chromakey and want to get the best result I can. Also is there a way that I can tell what the chroma is on clips?
Regards, Jerry |
Yes, one cannot get something for nothing, but I would be giving up spatial resolution - a factor of 2 for the width and height. My understanding is that 4:2:0 has the chroma subsampled by 2x2. I.E. each 2x2 block of pixels has a single chroma value. If this is subsampled by a factor of 2 for the x and y then one would get a chroma value for each pixel. Is there a flaw in my reasoning?
Regards, Jerry |
Yes I think I see where you're going. You're asking if you have a dime, and cut it in half, will you get two nickels.. :)
Someone more knowledgeable than me is going to have to answer your question for you. :) |
There are other technical details (e.g. in other cameras you'd have problems if the camera's sensor wasn't up to stuff, noise)... but you don't really need to worry about that. 2- Anyways, in practice: a- You can try to make the most out of Vegas' chroma key. Using the chroma blur and the secondary CC filters to clean up your keys is one trick. b- Or, you can use keying software like Ultra. (And a bunch of others on the market.) |
