Computer Crashed using vegas
Hi Folks.
I am/was in the middle of rendering a large 3-4GB file in AVI format to MPEG2. It was meant to take 4 hours and all was going fine for the first 2 hours. Then out of the blue. my machine just shut off. My computer is about 2 weeks old and is the following set up : Dual Core 2.6GHZ Processor Nvidia Geforce 8500GT Video Card 3 Gigs of Ram 3GB/Sec SATA Hard drive Windows Vista Ultimate 64 Bit I built this computer myself so I included an Artic Cooling system for the CPU and my case has several case fans, so it stays pretty cool in their. I have never ever had vegas crash like this. Is it possible that vegas got over worked?. My computer is not showing any signs of over heating at all. I have it also set to not shut of the Hard drive or go into sleep mode while rendering. Pretty strange issue. |
Hard to say without more information. What happened when it crashed? I've known computers to get weird errors and re-boot/shut off when the CPU or memory overheated. Is this computer in an air-conditioned room? Check the BIOS to see if there's some sort of power saving mode that's switched on. Double-check the system/hardware/hard drive settings, make sure they are set to "ALWAYS ON" or something like that.
sounds like a bad power supply, or an underrated one
has nothing to do with vegas |
HD is set to run at all times. My computer is in an Air Conditioned room that is around 70 degrees most times. Gets up to about 75 in the evening.
I dont know if it over heated or not, It showed no signs and If it is what happened, then i am highly annoyed with the artic cooling system I have. My power suplly is a 480W power supply and was recommended as a solid product. It runs fine and is used everyday for maybe 8-9 hours. But yeah, it just turned off half way during render. |
Check the windows log books, they should give you an indication what happened during the auto shutdown.
Could be you need a bigger power supply, it has happend to me. Get a 6oow and that should fix it. With drives spinning and proccesing /rendering going on, the poor old power supply takes a hit.
I could be wrong but that's what i would try. |
Another thought. Is the Windows or any other auto update turned on? Vista for example can do it's thing then shutdown automatically. I got a fairly major auto-update a few days ago and I caught it before it did that. Anyway another thing to check. Also Adobe Reader, iTunes, Quicktime etc.
Maybe it was updates, I have most programs on Manual for updates, but yes a few do update on auto mode. Thanks for all the great replies.
I will check out my logs and see what they say. |
