Paste Event Attributes Shortcut?
Is there a way to assign "paste event attributes" to a single key? I use this feature a lot so it would be very useful not to have to right click and locate paste event attributes in the list.
Frop "Options menu" select "Customise Keyboard"
Click "Global" - then scroll down the list of available commands until you see "PasteEventAttributes" - it's under the Edit section and on my installation is only about 20 commands or so down so you won't have to scroll very far. Click on "PasteEventAttributes" - then click in the "Shortcut Keys" box and type exactly they keyboard sequence you want to use. You will get a warning if you select a combination already in use. Once you're happy with your key combination click "Add",then click "OK" to close the Customise keyboard window. Ian |
Thanks very much Ian! I've looked for it before in "customise keyboard" but not in the "global" section. I can assign it to my jog shuttle now. Thanks for your full explanation!
