How to clear many gaps on the timeline
I can't find out how to clear many gaps that I have created cutings a parts on the timeline.
I have to "select the events to end" and draging and draging again on the left to connect all clips together.Any simple way??? Regards. |
Ripple edit works just be careful with it or you can double click in the open track area control X then control f will move the clips to the left on the timeline.
Don |
A thing I use is, when you're making up the timeline and leaving gaps for future material say more footage, use the Vegas text writer to briefly describe or number what the new insert will be.
You could even drag the text out to the length of the insert you intend, to keep a handle on the duration of your finished program. Also helps give you a feel for your show as you go along. Cheers. |
Excalibur has an option for close gaps I believe.
Edward? |
few years ago there was a free script on the VASST site ....
Yes, Excalibur will do this. Ultimate S will as well. There may be a free script out there as well that will do so. It's totally simple using a script, though.
Here's an "oldie but goodie" called DeleteEmptySpaceBetweenEvents.js that I found in my script collection.
It was originally a Sonic Foundry script but has been modified for Sony usage. I just tried it on Vegas 7.0e and 8.0c and it works on both versions. Credit for the script goes to Philip, whoever he is :-) Code:
