Downconverting HD computer Files to DV in Vegas
I have some AVCHD files on the PC I wish to edit in Vegas 8 as a DV project.
How do you import media in AVCHD which is already on the hard drive to appear as DV in the project? If I was capturing directly I would simply down-convert in the camera and then "Capture", but capture doesn't allow "Capturing" and downconverting into your project unless from a camera. Likewise I cannot see how to simply import media from the drive other than in its native form. It appears to me as if I would have to import the native HD file & then render it out to DV and then use it - ? The whole project is SD and my PC is apparently too slow to show the AVCHD files properly so it is too awkward to use these files on the timeline with other down-converted clips. The PC is a core 2 duo 2.13GHz. & NVidea GF 8800 GT RonC |
Just drop the files on the timeline. Vegas will handle the conversion fine for you.
If your computer can't handle the AVCHD files natively, just drop them on the timeline and render them to some other format like Cineform. You can also use something like AVCHD Upshift at newbluefx to convert the files from AVCHD to m2t. |
Thanks Edward.
I am not familiar with cineform or AVCHD Upshift. Are these separate program/codecs which I would have to buy or are they simple free downloads that work like AVI ? I have only edited so far in AVI and thought that editing in m2v was more difficult due to the GOF structure. RonC |
AVCHD Upshift is a third party product (see www.newbluefx.com for more info).
The Cineform codec comes WITH Vegas so you can render to that yourself (look under file type "AVI" at the various options). Cineform is also a separate product as well but you probably wouldn't need it. |
If you use PMB (the Sony utility) you can downconvert fairly quickly and easily as well.
Vegas can read many varieties of HD files but definitely not all. So any it can't read you'll need to convert. If you're using a Panasonic camera, you'll need to look at some options like Raylight or Cineform.
These TS files aren't from a camcorder. I captured them from a DVR using Hauppauge's HD PVR. I've been able to edit them with some freeware tools like H264TS_cutter and burn to standard DVDs without any problems. Do you have any recommendations for conversion programs? If not, then I guess I'll test some programs that have free trials and see what works best. Thanks for the reply, Edward. |
I downloaded the AVCHD Upshift trial and tested it on one of my TS files. I had to rename the file with a .m2ts extension, but it worked. The 10-second .m2t output file appears indistinguishable from the original. Now I'll see if Vegas can read the .m2t file.
Picture Motion Browser should have come with your camera on CD.
