Multicamera with Audio
I've created a multicamera track from two clips, each with a video and audio track. Everything is sync'd. Ideally, when I make a camera switch, I want to use just the audio that was originally with that camera. Currently, it sounds like all the audio is always superimposed. One of my cameras was closer to people in the audience who asked questions, so I want to "switch" to that audio when I go to that camera. So a basic question I have, what does the "Enable Multicamera Audio with Video" menu selection actually do?
thanks Jeff |
If that option is turned on, when you add a camera switch it will also switch the audio to the same take. So if you want the audio to follow the camera switches, you'd want that option turned ON. You'll also need to make sure the audio tracks are selected along with the video tracks when "Create Multicamera Track" is chosen.
