-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Batch rendering of projects? (https://www.dvinfo.net/forum/what-happens-vegas/141231-batch-rendering-projects.html)
Brian Boyko January 9th, 2009 10:51 AM
I found a way to batch render multiple projects (like Compressor) overnight. It's an $80 utility called Veggie Toolkit: Veggie Toolkit 3.0
Here's the question: Is there a way to do this without spending $80? And is Veggie Toolkit stable? It crashed on my Vista x64 workstation when rendering one particular project; (to be fair, the render continued in the background on the Vegas application - it was only Veggie Toolkit that crashed.)
I'd pay $80 for it, I think that's fair for what it does, but I'm wondering if there's any other way to do this workflow thing.
Garrett Low January 9th, 2009 11:03 AM
There is a script to do batch rendering but it requires you to have all of the clips int eh current project, then you set up regions for each render. The cool thing is you can render the same thing into a number of different codecs. That way if you need to render for say DVD and web delivery you can do it in one batch.
Edward Troxel January 9th, 2009 11:17 AM
Veggie Toolkit is a great option. There are other other scripts available that will render multiple projects including free ones. It's just a matter of locating them. There are several repositories of free scripts.
Brian Boyko January 9th, 2009 11:30 AM
For what it does, I'll pay the $80.
Jason Robinson January 10th, 2009 01:20 PM
I've wanted something like this for ages. I've taken to fooling vegas by openign a second instance of the render service under a different port and then throw the render jobs at that instance, but usually that just crashs my system. The only real way I've been able to queue up a few dozen different renders is to have a second PC act as the renderer, adn then on my primary PC open each .veg and kick off the render usign the network render service to the remote system. sure is a time saver, though not as fast as just beign able to queue up the renders on the same machine.
