Render uncompressed avi widescreen properly?
Shot in 16:9 SD with FX1000. My rendered uncompressed video is coming out squeezed. Used ntsc widescreen setting, made sure pixel are set to 1.2121.
The final render is coming out not wide enough. I don't have this issue with .wmv files. Anyone know what is up? |
Are you talking about rendering TO uncompressed avi OR attempting to render uncompressed avi that is on the timeline?
What is the end use of the media of your project?(dvd, web, etc.) |
Thanks Michael. I was rendering to create an uncompressed .avi file. I found that I was using the wrong setting. I should have used plain default uncompressed setting, instead I was using NTSC widescreen setting, but apparently since the project properties were already set to widescreen, I didn't need to tweak the settings for rendering.
