Timelapse script
Hi guys,
I'm at the point that next week i'll be shooting at a lake with the clouds floating... I'd like to make em fast in Vegas;wich settings should i use on my z1 hdv camcorder and wich script should i use in Vegas? thx a lot |
in Vegas you can insert a velocity envelope and go to 300%-then if that's not fast enough render the clip to DV-AVI and bring it back to the timeline and insert a velocity envelope at 300% repeat as needed.
You can also go into the clip properties and change the playback rate. That with the velocity envelope will give you 400% speed increase. |
Hey Don,i m talking about m2t files;i always do what u r suggesting me but I know there's a script!Please help me;ED do u know anything about that?
Ctrl-drag left to 400%, insert velocity envelop for another 300%. So that is 12 times faster. Don't forget to trim 2/3th of after the envelop.
Save it as xx.veg, import the xx.veg and repeat. 144x is often fast enough. |
In Excalibur, there's the Strobe tool that you could use to cut x frames keep y frames. Then you could use the gap/overlap tool to remove the gaps. I'm sure Ultimate S has something similar.
2 HUB:400%?I thought the maximum was 300% ...i can't wait to go back home on tuesdat 2 try....
2 my idol ED:for example i record 1 hour of clouds in the sky,then i put on the timeline;then if i had that Excalibur plugin how many clips should i leave and how many should i cut? thx a lot |
Depends on how fast you want it. If you want it 4 times faster, cut 3 frames and leave 1 (or would that be cut 4 frames and leave 1?) Bottom line is that you can cut any amount out using this method meaning you could speed things up 2000x if you wanted.
Any shutter suggestion 4 my z1?
How much does it cost excalibur and where can i buy it? |
Information about Excalibur can be found here.
I can't find the price!:(
Class On Demand - Product Description |
