magic bullet looks and vista 64?
the website says none of the programs are compatible, but then it also says that SOME are compatible. so, is MBL compatible with vista 64? I am getting my new laptop, and it comes with 64, but I will install XP if MBL wont work.
It should run fine on Vista 64 when using 32-bit NLE's. However, I don't believe it is compatible with 64-bit NLE's.
ahh, so if I am running vegas 8.0c, it should be fine?
Yes. Running 8.0c it would all work as you expect. Running 8.1, it would not be available.
thats perfect, thanks!
FWIW, in case you wanted confirmation of Edward's prediction, I can confirm that it works flawlessly in 8.0c, but it is not available at all in 8.1.
Steve |
