How to Export for Multimedia Drive
Hi
I've just exported two movies to my brand new Iomega Screenplay HD Multimedia Player; as follows:- PAL HDV and PAL DV, both exported ("make move") as AVIs using the default settings. When I come to playback on a TV from the multimedia player I get the error "CODEC NOT SUPPORTED". I would welcome any ideas on how I should go about viewing movies from Sony Vegas Platinum 9 for best results. Many thanks. |
AVI can be a lot of different things. Divx, Xvid, DV, etc can all be .avi files.
What format can the player support? Find the avi container format for that format. OR consider output as MPEG2? |
Codecs Supported
Thanks.
I've now found the list of Codecs supported by this machine. What would be the best for HDV to be watched on a "Full HD" TV and how do I do it from Vegas Platinum 9, please? Codecs and all that are a total mystery to me. https://iomega-na-en.custhelp.com/cg...i=&p_topview=1 Thank you. John |
Although it says "HD" on the box, that refers to the HDMI connection, not to anything it will play, I think. Indeed, DivX HD is specifically excluded in the list of Codecs supported. Not that I could get it to play DivX regular strength, anyway. So I've put it back in its box ready to be returned tomorrow for a full refund. I want nothing more to do with Iomega, ever! So can anyone recommend a good multimedia player, please, that will play some HD video, as rendered by Sony Vegas (Platinum Pro 9 is what I have). Otherwise, I'll save my money and go back to saving out to tape and playing from my Canon HV30 (I really wanted to save it from that chore). We're about to invest in a Full HD Plasma TV (Panasonic). So I want to see some stunning HD TV from my own camcorder! |
This looks like a promising candidate: LaCie - LaCinema Rugged They have a couple of other models too. I don't have any of these particular ones myself but I use other LaCie drives and have found them to be reasonably good for the money. For critical capture and rendering work though, I use G-Tech drives. |
What you are desceribing is similar in other machines, like the Western Digital. For HD I use the MPEG4 codec and it works just fine.
Thanks for the advice, Steve & Chris.
Wd tv
OK. I've bought the Western Digital TV Media player and like it, AND go it to work with HD MPEG2 files (as exported from Sony Vegas Platinum 9). Am I right in thinking MPEG4 would be a better format? I've tried but can't get the WD TV to play mpeg4 files exported from Vegas ("SONY" HD settings). I even tried renaming the file to .MP4 without success (this worked with the MPEG2 files by renaming to .MPG).
Also, I can't find a satisfactroy file format for DV files. (All my stuff is PAL 16:9 either DV or HDV) as there don't seem to be any DV 16:9 presets for this within Sony Vegas (MP4 or MP2) - only "video only" settings. This is a minefield for me and I am about to explode! Thanks for any help forthcoming!! |
