Project won't open - stuck at 6% - any thoughts?
Project wont open-stuck at 6% - any thoughts?
I think I know what the problem is – Magic Bullet Looks. But I don’t have a solution. I installed the plugin yesterday, worked many hours on a project, closed it, then tried to re-open it and…stuck at 6%. It won’t load the project further. I have another vrsion of the project saved as well – that one will only load to 2%... When I disable (rename) the magic bullet .dll file -- the project will load. I’m running Vegas Pro 8a. Downloading 8c now and hope that might help the situation. Clearly this plugin is causing a problem. I’d really hate to lose my many hours of work. I applied numerous instances of Magic Bullet Looks to individual clips all across my timeline. Any thoughts or anyone had a similar problem? Thinking of upgrading to a new machine – I’m on a somewhat now old duo core 3.2 ghz PC presently… might that be the problem? Thanks -- |
UPDATE:
Just installed 8c and the project now only loads to 1% - and no further. What gives?!!! Anyone? |
Further Update:
I just got the project to open - somehow. I opened a previous project that did not use any instances of MB. I clicked on a clip, then opened/applied magic bullet, then turned it off and exited the project. I then noticed in my Windows task manager that Looksbuilder.exe was present where it had not been earlier. It seems that if looksbuilder.exe is not running already (in the task manager>processes) when you open a Vegas project that has been saved with MB Looks applied -- Vegas won't open the project. Humm -- Anyone else experience this? Strange. |
