Will Vegas 8 split scenes in already captured footage
I got a 45 minute long AVI from an editor, which probably has 75-100 different shots on it, lumped into one big file. Does Vegas 8 have any way of splitting this file up for me, or can it only do that while capturing?
Thanks! |
That is the only idea I have. You might also be able to create sub-clips based on each scene in the single AVI. Then you might be able to reference the sub-clips on the timeline instead of the single big file. I don't know if that is of any benefit to you. What do you need the individual AVIs for? |
I don't think it will "automatically" do it. I think that you will have to manually split each scene.
I'd better charge for an extra bottle of editing juice (Scotch) then...
Dylan, if you want it split into different scenes into different files, that needs to be done during capture.
What format is the file? For SD, Scenalyzer will do it after the fact. Personally, I just drop it on the timeline, press "S" at the appropriate places, and then move them around as desired. |
| All times are GMT -6. The time now is 11:42 PM. |
