Help: DVX100a footage cropped on TV
I shoot in letterbox mode in my AG-DVX100a and then capture it using Vegas. The dimensions are 720 x 480. When I render, I'm now saving to a mpg2 format for SVCD, which outputs a file with 480 x 480 resolution. On a TV, this SVCD footage gets cropped on the left and right sides. What am i doing wrong? I want the rendered file to play on my TV like a 16x9 widescreen DVD and show all the image, not crop any of it.
By crop i mean the image itself extends further than what shows on the TV. Any help appreciated |
Hello,
Well I am not familiar with shooting with your camera.. But it sounds to me that when you are rendering to the SVCD format you say it crops it to 480 x 480.. If you crop a 720X480 image to 480X480 then you will be cropping it on the left and right sides, while maintaining the correct vertical size(480)..Its pretty simple math..If you change the horizontal size, while not changing the verticla size.. then you are losing 240 lines of info horizontally.. Mike |
the 480x480 conversion actually scales, instead of crops. Every part of the image is represented. Let's say on my computer monitor I open up the rendered mpeg. Horizontally I see this
123456789 (the full horizontal image) after burning to a CD-R, and playing on a TV, i'll see 2345678 meaning that some off the left and right isn't appearing. Anyone know what's wrong? |
Yes, it's called "overscan" and all televisions do it. That's what the "Safe Action" and "Safe Title" areas are all about.
John |
Hash mark
In vegas preview window you will find a small hashmark-button.
Clicking it will show you "safe zone" (outer) and "title safe" (inner) marks.. /magnus |
some questions, then:
1) Do most TV's overscan by the same amount, and is anything inside the safe zone considered safe for all (or most) TV's? 2) What's the best way to resize my image to fit in the safe zone? Right now I'm scaling the footage in Track Motion. Is there a better alternative? |
<<<-- Originally posted by Allen Nash : some questions, then:
1) Do most TV's overscan by the same amount, and is anything inside the safe zone considered safe for all (or most) TV's? 2) What's the best way to resize my image to fit in the safe zone? Right now I'm scaling the footage in Track Motion. Is there a better alternative? -->>> Why not just edit your footage without any track motion resizing (unless you specifically want a rotate-zoom or slide for effect) and just use the "Render As" command > select 'Mainconcept MPEG2' > then select SVCD NTSC or SVCD PAL as the 'template'> then click custom settings button > in the customs setting dialogue, click the "Video" tab > under 'Aspect Ration' select 16:9 display......You can now render out the file, or if you're feeling game you could see what's available under the other tabs....allow field based motion compensation might be worthwhile if you feel there might be heaps of action/abrupt scene changes.... The rendered file can then be written to CD in any SVCD renderer of your choice. Personally I prefer Nero's SVCD renderer for this but that's just me!!! |
Turn on the "safe zone" overlay in the preview window (button looks like #) This will put two new border lines on the screen. The inner line indicates the text safe zone. All text should remain inside this area. The outer line indicates the action safe zone. Quote:
<<<-- Originally posted by Allen Nash : I also use Nero's SVCD renderer. One thing, though: When I click "custom" nothing happens. I had assumed that there were no custom settings for mpg2. -->>>
I assume you're referring to Vegas 4's 'Custom' file format options button (under the 'Render As' command.....). Vegas is where you need to render the Mainconcept MPEG2 file. I hope I didn't imply that Nero has the options available for optimizing MPEG2 output... As you mentioned that you capture your DV directly into Vegas, I figured that the simplest approach would be to edit/finalise & output everything via Vegas (but without the need to crop or track motion your footage to get the proper 16:9 aspect). All you need to do with Nero is select SVCD as the CD type....A new window will be created with a 'Video_TS' & 'Audio _TS' folder in the left pane - and your file tree (for selecting the MPG file created in Vegas 4 that you wish to write) in the right hand pane. Drag & drop the *.mpg file written in Vegas 4 to the 'Video_TS' folder...No re-rendering of the file is necessary or asked for by Nero..... and then BURN!!!!!..... before serving up in any SVCD compatible DVD player. |
Yeah I meant the "Custom..." button in Vegas 4.0e after clicking "Render As" and selecting mpg2. When I click it, nothing happens, just like nothing will happen for other formats that have no options to customize. I wonder what's up with it....
What version is your mpg2 plug-in |
Yes, the custom button works. This is a known issue with some installations. Here are some old instructions to fix this problem:
[HKEY_LOCAL_MACHINE\SOFTWARE\Sonic Foundry\MC MPEG Plug-In\1.0\License] "key1"="" <--------- !!!!!REMOVE THIS KEY!!!!!!! "CurrentKey"="XXXXXXXXXXXXXXXXXXXXXXXXX" "InstFlags"=dword:00000010 "AppGrade"="0x0010" I'm sure you'll now need to change "Sonic Foundry" with "Sony Media Software" |
excellent, thanks Edward!!
