Error: media library default could not be opened. Why?
Hi Vegaspeople,
i have an issue with Vegas8.Since i changed the administrator settings an error window comes to my screen:Error: media library default could not be opened How can i fix this issue?Is it a problem that depends from the last admin "privileges"? thanks a lot guys, have a good day Stefano |
Just fixed the problem, thanks to the biggest Vegas expert in EU!
How did you fix the problem ?
It's always good to post the answers just in case someone else get the same problem. Cheers, Paul. |
Re: Error: media library default could not be opened. Why?
How do you fix this problem!? Post the answer when you get one! Thanks!
