Sound problem
I boot up my computer, Windows XP. The volume control slider (lower right toolbar along with the date and so on) is set halfway. I play a sound file using VLC player, or Winamp, or Windows Media player. No problem. All sound the same.
I load Vegas 8 and drop the same sound file on the timeline. I play the file and it sounds very much louder. Why is that? The Vegas sound preferences are set to default. Many thanks. John |
it is quite possible that the presets are wrong. No it is more than possible.
whenever I put audio on a track there are a few things I do. First I set the track header preset to the folowing. Noise Gate-I leave alone, Track EQ I also leave alone for prerecorded sound, IE Music. I use another preset I set up for stuff I record depending on what mic I use. The Track Compressor I set to -3 as a soft limiter. I also go to the lower slider and right click on it and set it to -6 (non add). I then run each audio track to a seperate bus and in the bus I set the compression to -3 as a hard limiter and route the track to that bus and the individual buses to the master bus. The master bus I set the compression to -6 and I also set the Wave Hammer to Master for 16 bit. Then if needed, I use an envelope to control the volume levels more precisely. It sounds like a lot of work but it takes about 30 seconds to do each track. I've run as many as 10 or 12 audio tracks (maybe more) and I do it the same each time. Actually picked up the compression tips from Douglas Spotted Eagle a long time ago and it really makes a difference. HTHs |
Problem solved
Thanks Don, useful information. Didn't solve the problem so I uninstalled and reloaded Vegas 8. Problem solved. Don't know what the problem was but now it does not matter.
Cheers... |
yeah, reinstall was my 2nd option ;-)
glad you got it worked out. |
