-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   7d slow motion workflow (https://www.dvinfo.net/forum/what-happens-vegas/468015-7d-slow-motion-workflow.html)
Dror Levi November 19th, 2009 12:17 AM
I am kinda confused with it.
I guess I don't understand what is the 60 FPS
I thought that when I will drop the footage to vegas it will play slow by 50% then the normal but that's not the case.
I would appreciate if some one can educate me about the work flow for a slow motion with footage from the 7d when shooting 720p @ 60 FPS
Brian Luce November 19th, 2009 03:39 AM
Put your 60fps clip on the timeline, point the cursor on the end tail of the clip, hold down control key and click and drag that clip tail with your mouse. You'll see little squiggly accordian lines on the clip and a little box inside the clip showing the % that it's slowed. Easy. Now play it and you should see nice slomo in your preview window.
Dror Levi November 19th, 2009 08:12 AM
Thank you
That was EZ
Mike Calla November 19th, 2009 09:21 AM
Alternatively, as you can do one thing in Vegas many different ways;
Right click on the clip > Properties > playback rate – Adjust here for more exact playback rates.
