Group and Ungroup while maintaining Audio/Video grouping
Hi guys,
Can anybody tell me how to ungroup a number of events but maintain the audio/video grouping for each particluar event? In other words I have grouped a number of seperate video events but now I need to make some edits. When I go and ungroup or clear, the audio is no longer grouped with the corresponding video for each event. Many thanks. Kevin |
Simply select and regroup the audio & video as required.
1 Attachment(s)
I might not understand your post, it is not clear to me. I'm thinking you might need to use the "ignore event grouping button" in this case.
Turn if off after your done. |
Thanks Steve and Jeff for the replies. Steve, I know of the regrouping function, and this is fine for 5 or so events, but what about when you have numerous events, 30+. What a time waste.
Jeff, what I'm asking is, lets say you group a section of events, 30 events or so and later need to adjust an edit. I have to ungroup the group but then all the video and audio events are not grouped. I was wondering if there was a way to automatically re-group associated video and audio files without manually doing it. Many thanks Kevin |
Kevin, look at what Jeff is saying. By using the "Ignore Event Grouping" button, you can adjust a single event WITHOUT AFFECTING THE GROUPING. Just click the Ignore Event Grouping button, adjust that one event as needed, and then click the Ignore Event Grouping button again. Now those 30+ events are STILL grouped but you've managed to adjust that ONE event you wanted adjusted separately.
Thanks Edward, I'm away from my production machine at the moment but doesn't ignore grouping also ignore the association between matching audio and video?
Yes. But if you're only wanting to adjust one video/audio pair, it's really simply to click the video, ctrl-click the audio, and proceed from there moving that one pairing.
Thanks Edward, I really appreciate it!
What would be helpful to know is exactly what kind of "edit" are you trying to do. That might cause us to recommend one method over another.
