Flip Video
Shot a video in which the best angles were often rotated see:
http://img514.imageshack.us/img514/1826/flipf.jpg 1280x720... I can think of a few ways to rotate it back, but looking for some suggestions on the "best way" keeping the aspect ratio correct and not letter boxing... Thanks! |
If you want to see the entire image, then you have no choice but to put up with the rather large black bars that result from doing a rotate on it.
Otherwise, open Pan/Crop on the clip, change the Rotation angle to -90 (or + 90 if needed) and crop (zoom in) as desired. |
Yea, Pan and Crop is the "ways" I had in mind - but was hoping maybe had some other tricks up their sleeve :)
For example, anyway to make me look like I'm farther back? Change the perspective a little bit for example so that they are farther away? |
2 Attachment(s)
What a lot of folks are doing in similar situations (me included), is to place the footage or still on a lower track, add Gaussian blur to it and then place the same footage or still on the upper track.
A blurred border (or anything else) can be added to the rotated footage/still to help it blend in better. edit: feel free to use anything image-related for the lower track as you're limited only by your imagination and creativity. |
Hrm....
Yea, that is something I should have but didn't think about.... What about track motion - I'm at my day job now so can't try it - but wonder if you could pull the perspective in 3d back some as well and then enlarge to fill in the screen more? |
