I Need SnapShot Script Help, Vegas 10 Pro
I really hope I am not being a pain. Snap Shots in my work is a major Must Have and will be a large part of my work flow.
I ran a search and did the Google thing. I have been having problems like, Links not working anymore, forum registration problems, and the ones I did find fail. I did get some info in a JetDV news letter but it is unclear how to apply it. The documet mostly talks about it. So........... :-° Any help would be great. I am willing to pay for a working script. Something that would put things back to normal after the shot is taken. I just cannot get my hands on one. I tried the below in two ways. One saved as a .cs and got the error message......... System.ApplicationException: Script file does not exist: 'C:\Program Files\Sony\Vegas Pro 10.0\Script Menu\SnapshotToClipboard.js'. at Sony.Vegas.ScriptHost.LoadScriptText() at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly) And the same file saved as a .js and got the following........ C:\Program Files\Sony\Vegas Pro 10.0\Script Menu\SnapshotToClipboard.js(17) : Variable 'VideoRenderQuality' has not been declared C:\Program Files\Sony\Vegas Pro 10.0\Script Menu\SnapshotToClipboard.js(21) : Variable 'VideoFieldOrder' has not been declared C:\Program Files\Sony\Vegas Pro 10.0\Script Menu\SnapshotToClipboard.js(22) : Variable 'VideoDeinterlaceMethod' has not been declared C:\Program Files\Sony\Vegas Pro 10.0\Script Menu\SnapshotToClipboard.js(25) : Variable 'RenderStatus' has not been declared ===== The Script Text Below ===== // This script copies a snapshot of the current cursor position to the clipboard import System.Windows.Forms; import SonicFoundry.Vegas.Script; import SonicFoundry.Vegas; // Save original Settings var origPreviewRenderQuality = Vegas.Project.Preview.RenderQuality; var origPreviewFillSize = Vegas.Project.Preview.FullSize; var origFieldOrder = Vegas.Project.Video.FieldOrder; var origProjectDeinterlaceMethod = Vegas.Project.Video.DeinterlaceMethod; try { // Setup Preview for image capture Vegas.Project.Preview.RenderQuality = VideoRenderQuality.Best; Vegas.Project.Preview.FullSize = true; // Set the field order and deinterlace method Vegas.Project.Video.FieldOrder = VideoFieldOrder.ProgressiveScan; Vegas.Project.Video.DeinterlaceMethod = VideoDeinterlaceMethod.InterpolateFields; // Copy Snapshot to Clipboard Vegas.SaveSnapshot() == RenderStatus.Complete } catch (e) { MessageBox.Show(e); } // Restore Previous Settings Vegas.Project.Preview.RenderQuality = origPreviewRenderQuality; Vegas.Project.Preview.FullSize = origPreviewFillSize; Vegas.Project.Video.FieldOrder = origFieldOrder; Vegas.Project.Video.DeinterlaceMethod = origProjectDeinterlaceMethod; // This script copies a snapshot of the current cursor position to the clipboard import System.Windows.Forms; import SonicFoundry.Vegas.Script; import SonicFoundry.Vegas; // Save original Settings var origPreviewRenderQuality = Vegas.Project.Preview.RenderQuality; var origPreviewFillSize = Vegas.Project.Preview.FullSize; var origFieldOrder = Vegas.Project.Video.FieldOrder; var origProjectDeinterlaceMethod = Vegas.Project.Video.DeinterlaceMethod; try { // Setup Preview for image capture Vegas.Project.Preview.RenderQuality = VideoRenderQuality.Best; Vegas.Project.Preview.FullSize = true; // Set the field order and deinterlace method Vegas.Project.Video.FieldOrder = VideoFieldOrder.ProgressiveScan; Vegas.Project.Video.DeinterlaceMethod = VideoDeinterlaceMethod.InterpolateFields; // Copy Snapshot to Clipboard Vegas.SaveSnapshot() == RenderStatus.Complete } catch (e) { MessageBox.Show(e); } // Restore Previous Settings Vegas.Project.Preview.RenderQuality = origPreviewRenderQuality; Vegas.Project.Preview.FullSize = origPreviewFillSize; Vegas.Project.Video.FieldOrder = origFieldOrder; Vegas.Project.Video.DeinterlaceMethod = origProjectDeinterlaceMethod; |
Re: I Need SnapShot Script Help, Vegas 10 Pro
version? system?
if you're having other problems to, then i think you'd best start off looking for problems elsewhere - virus, malware, etc., |
Vegas Pro 10c Build 470.
The problems are else where, not with my system but in locating scripts. Many of the links I have searched out are dead. I tried to join a forum and having technical difficulties and the administrators are slow getting back to me. Some scripts like the one I posted are for older versions. System? Home built by yours truly and heavily maintained, protected and pampered. Windows 7 Pro x64 Gigabyte Mobo GA-EP45-UD3P Intel Q6600 CPU - Stock Clock 8GB DDR2 CORSAIR XMS2 DHX - Voltage @ 2.1 (Mfg Recommended) 620W CORSAIR PSU CMPSU-620HX Modular POWERCOLOR AX3650 512MD2 Radeon HD WD 750GB RE3 x2 in RAID-1 System OS Drives WD Black 1TB Media Source Location WD Blue 1TB Media Rendered Destination WD Green 750GB Storage WD RE2 750GB x 2 in RAID 1 External eSATA Box Backups WD MyBook 500GB USB Misc Storage Dual Samsung 215TW S-PVA Displays, Pantone EyeOne Display2 Calibrated. Thanks |
obviously you know what you're running ;-)
so if you're using 10c, what happens when you use the snapshot button? |
In Pro 9, Sony added the following features.
* Copy Snapshot to Clipboard and Save Snapshot to File now deinterlace interlaced images and operate at Best (Full) resolution if the Video Preview is set to (Auto) size and Good quality if set to Draft or Preview. * Copy Snapshot to Clipboard now performs pixel-aspect correction like the Save Snapshot to File command. * Added Copy Snapshot to Clipboard and Save Snapshot to File to the Trimmer. A roundabout way of saying don't worry about having to change anything. |
The script you're using is a ".js" script. If you seem "import" - it's a js.
Here's my version for Vegas Pro 8: Code:
Thanks Ed, You said js twice. Just to confirm, its a .js yes?
Also, you get my PMe? Thanks |
Yes, .JS (as this one says "import". If you see the word "using" instead, it's a .CS.
And yes I did, and responded to it. |
