Help with track motion
I am having some problems doing something which I assumed should give me no trouble!! I want to make a small logo rotating on itself continously at the top left hand corner of my clip. What I am doing is, first change compositing mode to 3d source alpha, then doing resizing and moving the logo to desired position. And thats fine. Now comes my problem. When I make the logo rotate on the Y axis the perspective of the image changes as it turns around. If I leave the logo in the centre of the screen it rotates beautifully. Any ideas on how I can make this logo rotate in the corner without having a distortion in the image??
Re: Help with track motion
Thanks to John Rofrano for this tutorial.
Changing the 3D Track Motion Pivot Point |
Thanks for your quick answer Mike. I had already gone through that tutorial but thats not my problem. I try to explain better. I am having the effect, which I dont want, that the camera view is still in the centre of the screen. I want to have the camera view of the logo in the centre of the rotating logo (at the top left hand corner). Can this be done with track motion after all? Thanks for any replies
I get what you mean.
I'd leave it in the center, render it out with an alpha channel, bring the rendered file back into the timeline, then use 2D track motion to move it down into the corner. If you render it properly it can be an endless-repeating loop. Or . . . I have not tried this specific thing, so I'm not sure how the relationship in 3D space would work, but you could also try rotating the logo in a separate project, then nest the project in your main project and move it down to the corner with 2D track motion. However, that may be more of a pain than it's worth compared to just rendering out the clip. |
Thanks for your reply David. I tried your second idea, doing it in seperate project. It worked perfectly and I got what I wanted exactly. First I used track motion and then the pan and crop tool in the main project to move the logo to desired position. I love this forum!!!
