.MP4 Rendered video is all GREEN ! :(
Hi all :)
I've had this problem for a while now in Version 11. Renders fine in Version 10. Has anyone else had this problem ? Chris |
Re: .MP4 Rendered video is all GREEN ! :(
Sounds like an installed codec problem, or confusion between the codecs Vegas is using. Did you install any software that included codecs *after* your v11 install?
The likely solution is a reinstall of Vegas to see if that fixes it. You do have 4 different MP4 codecs to play with: Sony AVC Mainconcept MP4/AVC QT MP4 QT h.264 I highly recommend avoiding the QT MP4, very poor quality for bitrate. OTOH, maybe your guess is right and V11 has a broken codec. I wouldn't know because I never render to MP4 in Vegas any more. I render an intermediate file, then take that out to Handbrake which uses the very superior x264 encoder. |
Also happens if you're trying to render something with copy protection embedded in it -- thought that should happen in V10, too.
