Shuttle Pro & DVD Architect problem at DVinfo.net
Old January 26th, 2012, 03:51 PM   #1
Using DVD Architect 5.2 and have the latest driver for the Shuttle Pro, BUT can't get the outer ring on the Shuttle Pro to jog to the right. It goes left OK, but no matter what I try (changing the settings/key strokes) I can't get it to go to the right; no movement at all (FYI-Everything works well in Vegas 10). The inner wheel moves frame by frame correctly in both directions.
Anyone else have this problem? Any suggestions?
Herm Stork is offline   Reply With Quote
Old January 27th, 2012, 07:34 AM   #2
Sponsor: JET DV
Re: Shuttle Pro & DVD Architect problem
Did you load the Shuttle Pro file in the Vegas Pro 11 folder?
Old January 27th, 2012, 10:47 AM   #3
I have Vegas Pro 10 and no, the Shuttle Pro file is not in the V10 folder. Should it be?
Old January 27th, 2012, 01:49 PM   #4
It should be in c>Programs Files(x86)>Sony>....Should be three files for each of the shuttle models.
Ron Evans
Old January 27th, 2012, 05:23 PM   #5
C:\Program Files\Sony\Vegas Pro 10.0 for XP Pro 32 bit
Old January 27th, 2012, 06:14 PM   #6
I uninstalled the Shuttle Pro then reinstalled. The files are there, but still can't scrub forward in DVD Arch.
Old January 27th, 2012, 08:32 PM   #7
Did you install them from the Shuttle main window? Vegas 10 as well as DVD Architect 5 or whatever versions you have installed on the PC.
Ron Evans
Ron Evans is offline   Reply
