-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   60i upper field question (https://www.dvinfo.net/forum/what-happens-vegas/506463-60i-upper-field-question.html)
Jeff Harper March 28th, 2012 10:50 PM
I am editing my first project with footage shot in 60i that uses upper field rather than lower field. Should I expect it to play back fine on a DVD if it's rendered with same setting?
I'm having issues with the Bluray version of the video (I have to render progressive to avoid issues). Should I be concerned when I render for DVD using the upper field?
Eric Olson March 28th, 2012 11:29 PM
Re: 60i upper field question
If you are having issues with the blu-ray, I would expect the same issues with the DVD. What's wrong with the blu-ray?
Jeff Harper March 29th, 2012 07:24 AM
Eric, see my Weirdness thread and/or send me your email address and I'll send you a sample.
This is a serious issue, as I have found DVDA needs to recompress the footage after I rendered it to progressive, which I should have known. So as things are it will be recompressed twice, this really sucks since my customer is coming by in 5 hours to pick up blurays.
The DVD version of the footage when left interlaced sucks, it has interlacing crap and looks terrible, whereas with the Bluray it looks fine except for the bad clips, for which there is no rhyme or reason why they "jump".
I will never shoot interlaced again, I guarantee you that. My next wedding was shot this way and I dread working with it at this point.
