Exporting for DVD Architect
I have footage that was shoot in 30p. My export options are Upeerfiled first, lower filed first and none (progressive). Since the final result will be dvd which is interlaced, should I choose lower filed first or check none since the orignal footage is 30p?
Re: Exporting for DVD Architect
Choose none (progressive). When it is shown as an interlaced picture it will look identical to the 30p picture. I do this all the time.
Garrett |
Use the DVD Architect NTSC Widescreen template. Make sure to disable resample on all your clips. You won't see a difference in the footage, and DVDA won't have to recompress.
(Well, I assume it's widescreen. If not, don't use the Widescreen template. :) ) |
