Vegas vertical screen slider action...
Several times when I've gone to move down the screen by clicking and draging the slider bar on the far right of the Vegas screen, all my tracks minimise...which is a pain. I think once...maybe...they all maximized, but can't be sure on that one. They have definitely minimised several times...
Is this intended to happen, or is it a glitch? |
Re: Vegas vertical screen slider action...
May be You accidentally used keyboard shortcut ("`") to minimise all tracks?
If you doulbe-click the up/down slider, it will minimize all tracks. If you double-click it again, they will be restored. In short, it's a feature.
Thanks Edward. That's good to know...wondered if that's what was happening...
Ren if you hold down the "Shift" key your mouse wheel will vertical scroll instead of zoom.
On the screen shot I posted on another thread, I discovered after I posted that I had used the wrong angle for the pic in pic...I had thought it looked a bit steep...knocked it back from 51 to 39 degrees...looks better... |
