Pleae help with capture problem
No matter what deck or camcorder I connect I continue to get this message.
The device "Canon XL2" could not be opened. Please make sure that it is turned on and is not being used by another application or user. I checked and the computer lists the camcorder as being connected. This has just started to happen. Any suggestions? Bob |
Re: Pleae help with capture problem
Are you using the "external" capture application for Standard Def? The XL2 is SD, yes? If so, the "internal" capture app won't work with it.
Also, you may need to change to the "Legacy" firewire driver.
Seth, thanks for the reply. I have not changed any settings since I started useing Pro 10. This just happened over the weekend. What I ended up doing was to copy my DV tape to a DVD, then capture the footage off the DVD. That at least worked so I can edit the video
Ed, what is a "Legacy" firewire drive? Do you think that my video capture card needs replacement? Do you think upgrading to Vegas 12 would help? Thank you both for responding. Bob |
Do a search on Google for "Legacy Firewire Driver"
To get devices like the Canon XL2 to work on Win7, you need to use the legacy driver. |
In a pinch Bob, I've used Windows Movie Maker to capture when I had issues with Vegas capture.
Ed, you are truely the Vegas guru. I downloaded the "Legacy Firewire Driver", and everything works perfect. I am now a happy, happy editor. Thanks to all of you for your help. Happy Thanksgiving. Bob
